Leveling kits. Yes or no?
Alot of guys ( myself included ) go with AutoSpring, in the 2" variety. Some go 2.5" but I have read 3" is too hard on the BJ angle and will wear them out quickly. I got mine off Ebay for $73 delivered IIRC. After I get my Nitto TG 295/70-18s ( 34.4 x 11.5 I think ) I will save my change for a rear AAL or block to raise the back just a little more than it is now. Haven't decided which way I'll go yet. My buddy is getting a 1.5" installed in his tomorrow, S/Cab. I'm anxious to see how it looks.
Leveling kit
I got a Fat Bobs Garage kit from Ogden utah and the only things were the Shoulder nuts from my strut would not drop into the T6061 ring without hitting the edges. I called them and they were great and thanked me for the heads up. It was between 2-2.5 in. The only thing now is to aim my headlights. It looks great though.
I went with the Rough Country 2.5" caps in the front and 1" block on the back, with new shocks. Wish I could send you pic. Maybe soon. I work too much, I guess. Check it out. www.roughcountry.com.
so, has anyone gotten flak from the dealerships as far as warrenty issues?
needing front end work done,etc..
i have had issues with dealerships in the past with just regular warrenty work without any mods done...and really don't need the additional headaches from them...
i just opened my daystar 1" kit afew days ago...
i did notice that a dealer in southeast mich does sell daystar along with the install...but no one can give me an answer as far as warrenty work...
I had my wife take the truck in to get an AS 2" kit installed while I was in Iraq. I am happy with the kit but the place that installed it must have nicked the outer CV boot and the dealer won't replace it under warranty because of the leveling kit being installed. Those CV boots are pricey, but much cheaper than the entire CV shaft. BTW, apparently 09 and early 10s (like mine) have a different CV shaft design than later 10 models.
I like the way my 2" kit looks. It gives the truck a very slightly "nose up" appearance- More like a pre-runner. Some guys don't like it that way, but it's barely noticeable. I like that the kit is cheap, easy to install and maintains the stock ride quality. As long as you don't go too much (3" or more I'd say) you shouldn't have any ill effects. Just watch out for those CV boots.
Now, if they did a differential drop and the problem was multiple miles down the road, they still wouldn't warranty it due to teh Magnusson Moss Act.
Also, our 4runner has 100K miles on it and is leaking axle grease. We've decided that it's more cost effective to actually replace the axles when they start going out. I bring that up b/c unless your boots are just flinging grease everywhere, it might be a viable alternative.
Leveling kits are a good, cost effective way to lift a truck. Make sure you get a quality one. I'd stay away from ones that will rust and such, as well as pieces that are welded together. One piece pucks are going to be a bit better IMO for longevity.
I decided to go with new struts (coils and shocks) and am very happy with my decision on my Tundra. With the differential drop, no problems of 4wd at all.
I'm not sure how the Fords work, but anything over 2" on a Tundra (2.5" to level them out) requires a differential drop.
-rockstate
