99 7.3 psd will not start without a shot of starter fluid - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-23-2010, 04:29 PM
jwiseman jwiseman is offline
jwiseman is starting off with a positive reputation.
ok i have a 99 7.3l turbo diesel and i have recently been having alot of trouble getting it started. i know that starter fluid is bad for diesel so before everyone tells me..i already know..i have checked the hpop..not the problem, gpr, not the problem, glowplugs...not the problem. i know i have a slight fuel leak from the check valve that drains the water from the fuel..could it just be low fuel pressure? but when i shoot it with starting fluid or wd-40 it starts right up and runs perfect. o..and the check engine light randomly pops on only while im driving tho and especially when i punch the pedal...please helppp!!
Old 08-23-2010, 04:31 PM
onelionhunter onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
Codes
If the CEL comes on, you should have some codes stored. Know anyone with Auto Engenuity or a code reader that can pull your codes? that should be a good starting point.
Old 08-23-2010, 04:38 PM
i know a guy with a snap on code reader the really good one but he wont help me out...a normal code reader like the ones at autozone wont pull up anything
Old 08-23-2010, 04:39 PM
Reader
Yeah, teh cheap code readers can't handle our trucks. Where are you located, might be a member near by that could read your codes?
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
Sounds like your HPOP reservoir is leaking back into the crankcase. I believe the standpipe that regulates the height of oil in the res has an o ring at it's base, and once that starts leaking, over the period of a few hours your oil will drain back causing excessive cranking times for the lo press oil pump to build the supply back up. I'm guessing that once you shut it down, it'll start right back up right? Not sure how much you know about hte 7.3's but the injectors are oil press fired, which is why with no oil, no start. It's not the best design, but it's better in that you CAN'T blow the engine from losing oil pressure like yo ucan with just about any other engine in the world.
Old 08-23-2010, 04:40 PM
mongo75's Avatar
BTW- welcome to FTE!! Stick around a while and you'll go faster (probably due to a lighter wallet LOL)
Old 08-23-2010, 04:44 PM
no after i shut it down no matter if its hot or not it will not start at all without a shot of starter fluid. i even checked the oil level in the hpop, it was about an inch from the top, i recapped it and cranked it for about 15-25 seconds and then checked the oil level and it was still exactly the same...i let it sit for a few hours and checked it again...still the same level
Old 08-23-2010, 04:45 PM
BTW i live near akron ohio in a little town called lodi
Old 08-23-2010, 05:31 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
This is a good "No Start" trouble shooting guide.
__________________________________________________ _____________________________
Originally posted by Dave (Golfer) on PSN 01-20-2010 Thanks Dave
its nevvvvver the oil pump...seriously.
I see sooooooooooooooo many guys (dealerships included) that see "no ICP" or some ICP codes in a scantool...and toss HPOP's on truck after truck...when it is either an IPR or an injector (poppet valve) issue.
If you hook up the scantool, and monitor ICP (psi) while cranking...you'll see IPR% (duty cycle) climb & climb 15% key on..20, 30, 40, 55%, higher..the increase in IPR% means that the PCM is requesting ICP pressure to increase...
so ALSO watch ICP(psi) and if it comes up to only 180-250psi or so and stays there...then it's the IPR hung open (bypassing oil back to the oil pan through the front cover) such that only minimal psi can be made.
If the ICP is VERY low...like under 60psi...then it could be injector (poppets) pissing oil (under the VC's)..which is typical for injector with more than 180-200k miles.
if ICP climbs above 550-600..then it will probably climb much higher (15-1800+) and it is most likely going to be an electrical issue.
If his scantool will not connect then its a PCM or chip issue (remove the chip if you have one & haven't removed it yet)
if the scantool connects AND you have >600ICP then look at the datastream for a RPM reading.
if the scantool picks up an RPM signal and it seems accurate....then the CPS is good.
If no RPM on the scantool, replace CPS.
If you have RPM (on scantool, not just on dash)...AND have ICP >600, then run an (key on, eng off) injector "buzz test"...
the buzz test is nothing more than a continuity test from the PCM, through the IDM, and to & from each injector solenoid.
LISTEN to each inj buzz....do they all sound the same? nice & crisp?
if the test passes (and you audibly heard them all)...then wiring is good, IDM is good, HPOP is good...CPS is good...then it could be a fuel issue. gasoline, water, etc...
I wouldn't mention it if I haven't seen it myself numerous times...
any chance this no start began with 10-20miles after a fillup?
holler if you need help troubleshooting. take care~ Dave
Hears some good info also:
7.3L Powerstroke Starting Requirements:
Battery voltage a minimum of 10.5 volts while cranking
RPM at least 100 while cranking. If no tach movement suspect CPS
If you have a scan tool ICP should be 500 PSI 25 PSI and fuel
pulse width should be 1 to 6 milliseconds.
The above requirements assume the following:
Correct oil level, oil type and pressure
Correct type of fuel
Correct fuel pressure (53 PSI per Ford spec)
Sufficient air supply (clean air filter & unobstructed intake)
Proper oil level in HPOP reservoir (1 to inch from top)
Proper glow plug relay and glow plug operation (in cold weather)
Proper injection timing (PCM controlled)
Old 08-25-2010, 02:18 AM
the truck has been hard to start ever since i bought it, it used to only have a problem starting when the engine was completely cooled down. i think it started dooing THIS shortley after i changed the oil actually...which was maybe a month after i changed the glow plugs...i know that i have the correct oil and correct amount in it, so i dont really think that has anything to do with this though. if it were an injector wouldnt i notice it while i was driving?when i crank it over the RPMs are at around 200..its getting fuel, and the battery is giving it plenty of juice. could a clogged catalityc converter be the problem? could something have happened when i changed the glow plugs??
Old 08-25-2010, 08:00 AM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
"THIS shortley after i changed the oil actually...which was maybe a month after i changed the glow plugs.."
I would have to go through the glow plug circuitry again.
Old 08-25-2010, 08:26 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
When it is running, how does it run? Rough? smooth? Is your WTS light coming on? How long have you been starting it with starting fluid? Is there any smoke coming from the tail pipe when you crank it over?
Old 08-25-2010, 10:05 AM
1996pwrstrk's Avatar
1996pwrstrk 1996pwrstrk is offline
Wrench Party Assistant
1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.
Before you go any further you need to get those codes read.
Old 08-25-2010, 11:47 AM
megawatt00's Avatar
Quote:
I agree Dave with out it all we can do is guess............
Old 08-25-2010, 11:58 AM
rad1026's Avatar
rad1026 rad1026 is offline
rad1026 is starting off with a positive reputation.
I'm sure I read here at some time that it was not a good idea to use starter fluid in a diesel.
New to the site, Need HELP! 1993 7.3 Probull Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 04-30-2016 09:34 PM
89 f250 won't start Cerberus50 1987 - 1996 F150 & Larger F-Series Trucks 0 11-11-2014 11:36 AM
1994 F-250 7.3 IDI Tach Problem? broncrider051990 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 07-09-2013 03:21 PM
96 E350 7.3l diesel no start SSSFiber 1968-2013 Full Size Vans 2 05-09-2011 12:21 AM
My 92 Ford 7.3L bus wont start! Help me! raceopticsbus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 02-13-2007 07:26 PM
Tags
1999, 2000, 450, 50, 73, duty, fluid, ford, powerstroke, start, starter, starting, super, v10, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
