99 7.3 psd will not start without a shot of starter fluid
he knows LOL....
Glow plugs may be good or bad, but with 80* air temps, that shouldn't be an issue right now. You're either losing oil pressure or fuel pressure. Pull the codes and see what hints they give.
Starting fluid is specifically for diesels, it's just a bad idea in our PSD's because of the glow plugs acting as an ignition source.
find out how much fuel pressure you have at the fuel bowl. You will need to at least put a temporary mechanical gauge at the fuel bowl to check the pressure. Mine did the same thing and found that all the fuel was returning to tank and not making any pressure at the fuel bowl. When I blocked the return line with a little piece of balled up rag it went from 0psi to 30psi and started immediatly.
My 2 cents worth.
My 2 cents worth.
...ill get the codes pulled tomorrow at the HP diesel shop down the street and see where it goes from there...ill keep you posted and ask more questions if need be..thanks for the help guys!
My 2 cents worth.
My 2 cents worth.
Well, you definitely want to get new o-rings in there, HOWEVER, you better have a leak running down your driveway to substantiate that much of a pressure and volume loss. It'll run on 30 psi (not good for the injectors though) but the fuel pump IIRC is pushing about 360gph, which would equate to a 6 gal a minute flow coming from your fuel filter. I might be wrong on the numbers, but either way it'll be a REAL bad leak to ake the truck not run. I second a faulty fuel pressure regulator.
My original post "find out how much fuel pressure you have at the fuel bowl. You will need to at least put a temporary mechanical gauge at the fuel bowl to check the pressure. Mine did the same thing and found that all the fuel was returning to tank and not making any pressure at the fuel bowl. When I blocked the return line with a little piece of balled up rag it went from 0psi to 30psi and started immediatly."
so chances are...if i replace the water drainoff valve thats leaking, my fuel pressure will probally increase and may start?? because its leaking pretty bad...i just cant seem to find a damn parts store that sells anything for my truck!! can you point me in the direction of a good...CHEAP..or at least reasonably priced parts store? please and thanks
Originall posted by mongo75 "Well, you definitely want to get new o-rings in there, HOWEVER, you better have a leak running down your driveway to substantiate that much of a pressure and volume loss. It'll run on 30 psi (not good for the injectors though) but the fuel pump IIRC is pushing about 360gph, which would equate to a 6 gal a minute flow coming from your fuel filter. I might be wrong on the numbers, but either way it'll be a REAL bad leak to ake the truck not run. I second a faulty fuel pressure regulator."
I was talking about the fuel returning to the tank because of a faulty fpr which is at the top right of the fuel bowl if your're standing in front looking at the engine. the drain valve at the fuel bowl would have to be leaking profusely to not get any pressure if the fpr is good.(you should fix that leak though) regardless of what's going on it would still be a good idea to check fuel pressure at the bowl to at least eliminate problems. May also be a faulty fuel pump or clogged screens in the tank which a pressure check would show. let us know what you find
dude , one squirt of zippo lighter fluid down the throat, and you can get in iand it will fire up without blowing the precombustion chambers. i already replace my high pressure oil pump and put new O-rings on my injectors, still screwed brother, if you come up with any thing good let me know marktwach@gmail.com
#28
#30
