2011 Super Duty tranny problems
#556
I have had nothing but problems with my 2011 Ford 6.2 F350 transmission as well. I would get a "jerking " motion if I shifted truck from gear (2nd gear) to neutral. Also had 2-3 shifting issue first thing in the morning. Anyway approaching end of warrenty period I still had a tiny transmission leak, so took to dealer. Said I needed a torque convertor. 4 weeks later (mid-april) went down to get torque converter replaced. Tech took apart tranny and said metal shavings everywhere......need new tranny. New transmission was installed (apr 23). Today I started having shifting issues again. Big "jerks"..... when I would hit 60km/h then let off gas there would be a small "jerk" as the tranny ****ed up. If I hit 60km/h then let off gas for a second, then gently touch the gas pedal again, I would get a big "jerk".
I dont know what to do anymore. I did go to local GM dealer on Sat and drove the duramax with the Allison. I stopped short of buying. I am still in process of getting truck appraised (2nd opinion) for trade in. Then I will decide what to do.........what else can I do???.....I have a good contract and I have to get the job done!
#557
Read the first 10 pages plus a few posts as I skipped 5 pages at a time until the end.
Bought the 2011 used 2 months ago. Had the problem 3 times always accelerating from a cold engine. For me it feels like a slip; revs go up but no motion and when it finally grabs it's under compression so it feels like brakes are applied for a second. Everything is fine after that; don't need to put it in neutral or stop the engine. I just keep driving and don't have problems after that.
I will ask the dealer to check it out at my next service. Don't know if I have the old flash version or old solenoids.
#558
my 2011 tranny has been perfect since the reflash and 3 solenoids a while back for the shift flare problem common in the first year of build.
I was a manual tranny fan for the previous 5 trucks, Chevy's and Fords. Super happy with my 6 speed, love the manual shift mode. Sorry yawl are having difficulties.
It is not possible that the one truck will not shift out of 2nd until 95 mph....... sounds like a fish story. Mine will run 6,000 rpm redline at maybe 62-65mph. Even if the truck was stuck in 2nd gear, the engine ECM would stop if from fueling/igniting likely a few hundred rpm above redline.
So, in short, be careful what you call fish stories and making an assumption based on your sole experience!
#559
I'm not totally happy with my tranny. It is having some of the same issues in this thread.
Just feels sluggish...and likes to be in the highest gear possible ALL the time. Running in traffic and slowing to 35 from 60 or 65...it never downshifts. Not until 34 and drops to 5th gear. Strange! IMHO!
If the tranny could be in the correct power band...then the 6.2L would be an awesome engine. As it is...IMHO...it struggles to handle the weight of the truck.
Does anyone actually know the date and version of the latest and greatest tranny flash?? Just curious...
biz
biz
#561
Mine does the same but I see it as a fuel saving measure. If for some reason I want it to stay in lower gear while I town I can use the tow/haul button or I guess you could lock out all gears above what you want.
#562
My new 2013 had the 2nd gear hang up pulling my 5th wheel home on Monday. My wife looks at me like WTF?
Not a fan of this tranny.
I wish I could have my '06' tranny with this 6.2!
I have to wonder about the Mercon lv.
My gut feeling is the Mercon sp was superior, but the lv is cheaper to produce.
I have absolutely no evidence or studies or anything other than a gut feeling,
the same feeling I had learning about the Ford GOLD coolant.
#563
Probably so...but unfortunately I will not add an aftermarket tuner. Just no way...No how.
If a warranty issue comes up...and get told by FORD to push off because of the tuner. Naaaa...not my idea of fun.
Have to leave the motor and tranny all OEM stock until warranty is gone. But...might have a new truck by then. One never knows. LOL!
So...I wanted to qualify what I said about my tranny. The issues...are when I drive it easy and responsible. Going for MPG and all. However, when I drive it with some spirit...and get the RPM's up...the tranny is SPOT on!! Seriously...I runs GREAT.
I'm just not a fan...with the lazy and I mean lazy downshift patterns. It makes the engine lag some...and I don't think FORD has it right with this engine and tranny combo. At least not with the current OEM program.
biz
#564
Same problem
My concern with the tranny/6.2 combo is with downshifts on hills. I usually have a 8 1/2 x 16 cargo trailer hooked up and I'm finding that the transmission just slams down into 2nd from 5th or 6th when we hit a hill at highway speed. It'll rev the engine right up to the 6000 rpm redline. All of this is with cruise control engaged...
I'm hoping to get to the end of my work season before I run it back to a dealer. Is anyone else finding this sort of behavior or is it just me?
#567
2015 trans
2015 SD here, my 2015 will shift from 5th to 2nd also while in tow haul when pulling my 38 foot 5th wheel up inclines, without need. I agree with RV Puller, now I use M and stay in what gear I feel the truck needs while pulling hills, usually 1 gear lower. With the adaptive learning on my trans, it will not shift into 6th at any speed under 45 mph in town, I have always locked out 6th gear since the truck was new for slow driving. 6000 miles on it currently.
#568
Still going...
So I have had my new truck for exactly two weeks I've put about 750miles on the truck some of which has been in heavy heavy snow. That being said I've noticed some jerking and things and poor shifts but thought it was due to the lack of traction.
Since it has cleared up and the weather gotten warm (50 - 70) I've come to realize it is a transmission problem. I've had some poor shifts as well as missing shifts. Going from Park or Reverse to Drive does it the worst, truck will rev (no motion), then grind, then jerk into drive. Yeah for a car/truck person it is VERY embarrassing esp with the temp tag on it. I NEVER park without the parking brake and always shift at a dead stop with the pedal mashed all the way down just habits I've always had. I haven't figured out anything that can cause this to occur on demand but it's happened at all inclines and declines as well as on flat surfaces and of course it's when I'm parking. The grinding is VERY audible and disturbing it sounds like your hitting the reverse gear in a manual transmission while your driving forward without using the clutch! The fact that it happens at a dead stop makes no sense to me.
I don't have as much trouble with the bad shifts lately more so the miss shifts but have gone from getting about 15mpg (in snow with 4wd on at times) to getting 12.5mpg (in clear weather) so I have a feeling this may be to blame. It is driving me nuts with such low miles I picked it up with only 35miles on it no trouble, then it got snowy so I figured that was to blame now its more and more frequent. Since about 500 miles it has happened about 4 times. I have a long trip scheduled for later this week and have no doubt the truck will do fine but it does annoy me to say the least. I will be having them look into it as soon as i return next Monday.
So here I am nearly 5 years later and at 85k miles truck still shifts like trash but after nearly giving up I posted on another forum and a Ford service rep is going to look into what happened. Maybe it'll get fixed. I'll update what happens as this was the first thread for the issues and people are clearly still having problems.
#570
2011 trans problems
540milotalon
59
05-30-2021 09:47 PM
