Fuel Filter Location - Ford Truck Enthusiasts Forums
Old 08-23-2010, 01:53 PM
Roller150 Roller150 is offline
Roller150 is starting off with a positive reputation.
I'm getting ready to change my fuel filter on the 79 f350 with 460 in it. I have looked in the repair manuel for the locations but I cant find anything. I know there is the small one on the carb but is there an inline filter on the fuel line anywhere? I have not looked around really yet but I figure I would ask so I can go right to the spot it should be. I looked on the parts store websites and two of them show the carb filter and another one shows an inline filter so I bought the inline filter. The carb filter was clean.
Old 08-23-2010, 02:11 PM
pcskies's Avatar
pcskies pcskies is offline
pcskies is starting off with a positive reputation.
Not sure if this applies to your truck, but I discovered a few months ago that my 73 390 is suppose to have an inline filter before the fuel pump, but a PO must have removed it. It would have been a metal canister with a removable paper element type filter inside. You can still buy the paper element filter refill at the auto stores. And I believe Dennis Carpenter sells the actual canister.
I run the filter at the carb and also a 'see through' inline filter before that.
Old 08-23-2010, 03:21 PM
Ok thanks. Well the one part store calls for an inline filter that is thin and metal, but the other two only show the carb filter so I was wondering if I got the right part or if there is more than the one small rock filter that goes in the Holly 4b carb.
Old 08-23-2010, 06:05 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D3AZ9155C .. Fuel Filter-Threads into Carburetor / Except 429/460 / (Motorcraft FG14C).
Fits: 1965/79 2V Passenger Cars (& 1965/66 4V) / 1973/79 F100/350's / 1966/79 Bronco's / 1965/79 Econolines.
D3OZ9155B .. Fuel Filter-Threads into Carburetor / F100/350 & Econoline-Use with 460 4V (Motorcraft FG19C).
Fits: 1967/78 4V Passenger Cars / 1973/79 460 F100/350 / 1975/79 Econoline 460.
Both these filters were also used in 1980/90's vehicles w/o EFI.
C4AZ9365B .. Cartridge Fuel Filter (Motorcraft FG1A) / Available from Ford.
Fits: 1964/72 F100/350 I-6 & V8 / 1973/76 F100/350 360/390 / 1963/64 & some 1965/71 Passenger Cars.
This filter fits inside a cannister that threads onto the fuel pump. Most people are unaware it's there, so it rarely gets changed.
C3AZ9355A .. Cartridge Fuel Filter Cannister / Obsolete
Even though obsolete, it can be found from repro parts sellers, obsolete parts vendors and some FoMoCo Dealers.
D1AZ9A011A .. Plastic Meshed Filter Screen- 3/8" I.D. / Use w/o In-Cab Fuel Tank / Available from Ford.
Fits: 1965/79 Passenger Cars (except Maverick/CometPinto/Bobcat-all 5/16" I.D.) Econoline & Bronco / 1968/72 F100/350 with Mid-Ship fuel tank / 1973/79 F100/350 w/Mid-Ship & Aft Axle fuel tanks.
This screen slides onto the end of the fuel sending unit's pickup tube.
Old 09-09-2010, 09:54 PM
robertbenita robertbenita is offline
robertbenita is starting off with a positive reputation.
PCSKIES...where was your inline fuel filter supposed to be? Looking for another besides on side of carb...Thanks...
Old 09-10-2010, 09:05 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
You should check the entire fuel line all the way back to the tank, because regardless of what would have come from the factory, a previous owner could have spliced in an inline filter anywhere he saw fit.
Old 09-11-2010, 02:52 AM
Thanks! No filter other than on carb. And now brand new!
Is there a filter for the C6 qman 1967 - 1972 F-100 & Larger F-Series Trucks 8 07-01-2015 06:26 PM
86 Holley 4180 c Fuel filter help. The Golden Girl 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 11-17-2014 08:22 AM
fuel filter questons (83 f250, 7.5) PDXF250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 01-17-2012 07:57 PM
Question about fuel filter on 390 pcskies FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 11-09-2008 06:23 PM
Diesel vs Gas Fuel Filters... Beast12 Fuel Injection, Carburetion & Fuel System 6 02-06-2007 01:56 PM
Tags
1973, 2007, 79, 96, bronco, diagram, diesel, expedition, f150, f350, filter, ford, fuel, location, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
