Fan rubbing on shroud
I've been having that vibration problem lately. So annoying, but Its not a wheel bearing.
Hubs are staying cool, and no play.
I got a clunk sound like something is moving now, thats annoying.
anyways.
Should I assume that fan rubbing on shroud is from motor mounts? I really don't want to do motor mounts. =(
Thats just going to eat into my electric fuel funds. =*(
It's fine when its stopped, I have plenty of clearance all around, and I cannot move the shroud, so I only assume the engine is moving, because I cannot get the fan to wiggle any.
anyways.
I'm almost guessing that the bearing sound I've been hearing is the fan hitting the shroud.
I should pull it and see if it makes a difference. Not that the shroud is needed. haha.
The popping sound could be the motor moving in the mounts as well
Anyone here done motor mounts without pulling the motor?
Yes I worked my butt off trying to get rid of a rattle after the 3" downpipe install.
Got to looking at everything real hard, the front cab mounts and radiator support mounts were in bad need of changing.
New mounts, no more rattle.
Bad motor mounts could let the motor torque up, but bad body mounts move the shroud down.
But there is over 1/4 inch clearance when the truck isn't running
I'm not sticking my hand down there when it is either.
I woulda lost em on my 95 if i had not been wearing gloves.
I was adding radiator fluid and squeezing the top hose, my fingers got tired, so i put my fingers under the shroud and wham.
Stung a bit, but I bet if i wasn't wearing gloves, I woulda lost a finger. or 2.
Total brain dead moment, not sure what the deal with that was that day.
Scotty's 52 F3
11-15-2015 03:47 PM
Kelley11
05-22-2015 01:54 PM
