Melling LPOP Install
#46
I cannot stress enough that you may want to rent a balancer set tool. It threads all the way into the crank and uses the factory washer and a nut to set the pulley. Places like autozone and advance etc. have these. If not something like this might happen....Especially if you have luck like mine.
#48
I threw in the towel and sold the damn thing!!
Just kidding, a buddy is coming over today to help, he is going to retap the crank and we are going to set the dampener. Picking up a new bolt tomorrow. I had to work in the firehouse yesterday and to tell you the truth I needed to walk away from it for a day. We had four row houses on fire yesterday so I got to take out a lot of frustration! I feel much better today. Lol
#49
#50
#51
#52
#53
Autozone has a loaner tool for removing the fan. Some have used an air chissel. You don't need more than 10-20 psi to remove it. If you want to use an air gun on the damper bolt you'll need to remove the radiator. That is what I did and was pretty easy. Good time to clean between the fins. I was surprised how much dirt was stuck in mine. If you don't use an air gun you have to use a tool to keep the engine from turning while you remove the bolt. I think Stewart posted a pic of the tool he used in this thread.
#54
#55
#57
don't need to pull fan or radiator. I did mine in an RV campground parking lot. 20 degrees and spitin snow. I did pick up a slightly longer bolt to start the pulley back one with. Cheryl had to sit in the truck with her foot on the brake/the truck in gear to get the blasted thing back on and torqued down!
Barney
Barney
#58
#59
What do you guy. s think is acceptable for oil pressure. I just plumbed a gauge to the top of my HPOP and I have 20 PSI at idle hot and 40 while driving. Never goes over 40 and occasionally goes to about 15 while idling. I just wanted to do a before and after reading of the oil pressure...
That seems a little low at idle. I was seeing around 45 psi before I changed my pump. I was checking at the test port by the oil filter. I think 10 psi is the minimum low spec. I did not do a before and after test. I'll edit my post with checks for wear on the lpop with some feeler gauges. Mine were out of spec. I had a hard time finding something that was planar and got some different readings.
On edit here are the links:
https://www.ford-trucks.com/forums/m...p-testing.html
https://www.ford-trucks.com/forums/m...clearance.html
#60
