Flickering Check Engine Light, Loss of Power 1997 F150 5.4L - Ford Truck Enthusiasts Forums
Old 08-22-2010, 05:18 PM
diver doug diver doug is offline
diver doug is starting off with a positive reputation.
Recently the Check Engine light would come on for a day or two and go out. Today it began flickering (later stayed on solid) and it had a loss of power and began running rough. The engine has 310,000 miles. What could this be.
Diver Doug
Old 08-22-2010, 08:11 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
Diver Doug
At 310,000 miles it's probably telling you that it's tired and it's time for a rebuild. How is the oil pressure gage reading? Is it in the middle and steady or low and sometimes fluctuating rapidly? In the middle can still be low oil pressure as the gage will read "normal" at 7 psi and over.
Old 08-23-2010, 10:34 AM
Thanks for the response. Oil pressure is good, always steady. The gauge reads a bit above the middle. When the milage was just about 200K I replaced the heads (pin hole leak had developed leaking out coolant). That was about 4 years ago. The truck has run great ever since then until now. Now I am thinking maybe the spark plugs. Does a check engine light occur when plugs start to mis fire? Or could this be a coil problem?
Old 08-23-2010, 11:12 AM
Moto Mel's Avatar
[quote=diver doug;9249373]Thanks for the response. Oil pressure is good, always steady. The gauge reads a bit above the middle. When the milage was just about 200K I replaced the heads (pin hole leak had developed leaking out coolant). That was about 4 years ago. The truck has run great ever since then until now. Now I am thinking maybe the spark plugs. Does a check engine light occur when plugs start to mis fire? Or could this be a coil problem?[/quote]
It could be either and it will usually cause the CEL to come on and set a code.
Old 08-24-2010, 07:46 PM
iwmoose iwmoose is offline
iwmoose is starting off with a positive reputation.
I had the same thing happen to me and it was a spark plug problem.
Old 08-25-2010, 08:44 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It is a misfire. Pull your fault codes so you know where to look. Most common failure is a COP.
Old 08-30-2010, 06:03 PM
Thank you. I did realize the plugs had about 113K on them so I changed the plugs. For a few days the Check Engine light was off but the truck still had some hesitation and misfiring. After three days when passing on a hill the cutting out came back and the check engine light came backon, flashing. It flased for about 20 minutes and then stayed on continously. A few hours later the light is out. If this is a coil problem wouldn't I have continous sputuring and the light on?
Old 08-30-2010, 08:55 PM
READ THE CODES! DO NOT GUESS.
Battery indicator flickering on/off losing power Steck804 1997 - 2003 F150 5 05-27-2014 11:07 AM
HELP! Major elec. problem, Ex won't start, battery draw w/ key off 12valveEx Excursion - King of SUVs 10 08-16-2013 09:24 PM
Ecoboost/truck camper diver110 2009 - 2014 F150 6 10-13-2011 06:17 PM
98 expedition battery light flickering hornsurgeon Expedition & Navigator 14 10-08-2009 06:13 PM
flickering lights JoSHN Explorer, Sport Trac, Mountaineer & Aviator 3 11-08-2008 08:56 PM
Tags
1997, cel, check, engine, f150, flashing, flicker, flickers, ford, light, loss, misfire, oil, power, pressure, solid, sudden
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
