Vacuum Diagrams - 1987 F150 - Ford Truck Enthusiasts Forums
Old 08-22-2010, 11:21 AM
tdcarter72's Avatar
tdcarter72 tdcarter72 is offline
tdcarter72 is starting off with a positive reputation.
It's been awhile since I have posted. Most of the time, I can find what I need by doing a search of the forum, but not this time.
I am in need of any and all vacuum hoses diagrams that I can find for my truck. I am in the process of trying replacing all of the 23 year old hoses that I can find. This all started hunting down a vacuum leak on my EGR valve. Most of the hoses that are installed are cracked and wethered real bad and it seemed like the thing to do before winter gets here.
I know, I know, I need to buy the Ford manuals. My wife asked what to get me for my birthday next month and I told her the Ford manuals.
I have a 1987 Ford F-150 XLT 4x4 5.0L 302 automatic transmission.
If you need anymore infomation, just let me know, and I will get it posted.
Thanks for any and all help!
Old 08-22-2010, 02:58 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/98...m-diagram.html Read the post in this thread by rla, may help.
Also recent thread here with a download of a Haynes manual if that helps.
Old 08-22-2010, 03:38 PM
tdcarter72's Avatar
Lazy K,
Thanks for the thread. I had already tried that website, but it starts at 1988 and I have a 1987. I am sure one of those are close to mine, but I don't know which.
I am going to try to find the thread on the Haynes download now.
BTW, where can I find my Calibration Code on my truck?
Old 08-23-2010, 05:32 AM
http://www.ford-trucks.com/forums/98...ilar-book.html Here is the thread with the link to the Haynes.
Sorry the other link did not help.
Another thing you could try is to register with the the repair section of autozone.com (free) then fill in the details of your truck, click on "emissions" and you should get the full vacuum diagram.
No idea on the calibration code.
Old 08-23-2010, 08:41 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Originally Posted by tdcarter72 View Post
... where can I find my Calibration Code on my truck?
Sticker on the valve cover???
Old 08-24-2010, 06:42 AM
tdcarter72's Avatar
Vacuum Diagrams - 1987 F150 ---- UPDATE
Ok, I now have a diagram for my truck, but I need some help with some of the abreviated parts listed on it.
Here are the abreaviations that I don't know what they are:
A/CL DV
A/CL BI MET
FPR
ACV
VRESER
Thanks for any help with this.
Old 08-24-2010, 07:21 AM
pedant
Answers inline.
Hope this helps...
A/CL DV =Air Cleaner Diverter (fresh air flap)
A/CL BI MET =Air Cleaner Bi-Metallic (a heat actuated valve)
FPR = Fuel pressure Regulator
ACV = Air Control Valve
VRESER =Vacuum Reservoir
Old 08-24-2010, 07:46 AM
pedant
Took me a while to find it, but this is a really helpful post: Ford Truck Enthusiasts Forums - View Single Post - Vacuum Diagram Acronyms
Quote:
Originally Posted by AsianSpanker View Post
I have had such a hard time figuring out my vacuum hose routing and what each thing does I thought I would post what I have so far. I have a 1981 F-100 with a 302 2 BBL. I found about 30 different ways this engine has the hoses routed in the Library. And everything is in Acronyms.
VACUUM DIAGRAM ACRONYMS
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACV: Air Control Valve
AIR: Ford calls this the Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: Air Bypass Valve (aka Thermactor Air Bypass TAB)
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CPRV: Canister Purge Valve
DIST: Distributor
EGR: Exhaust Gas Recirculator
EFCA:
FLTR: Filter
FPR: Fuel Pressure Regulator
IVV: Thermactor Idle Vacuum Valve
MAN VAC: Indicating Manifold vacuum-Vacuum source
MAP: Manifold Absolute Pressure
SOLV: Solenoid Valve
SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
VAC:
VCKV: Vacuum Check Valve
VRESER: Vacuum Reservoir Solenoid Valve
VRV:
V CK V: Vacuum Check Valve
VRDV: Distributor Retard Delay Valve
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches)
PURGE CV: Vapor Canister Purge Valve
Color Codes to do Vacuum Diagram
Red = Main vacuum
Green = EGR function
Orange = Heat control Valve (exhaust & intake) (AKA heat riser but more complex)
Yellow = Distributor advance
White = EGR vacuum (source)
Black = Mainly used for the Evaporative emissions control
Black = Thermactor ACV or Diverter valve
Blue = Throttle Kicker control
Pink = Thermactor Air Bypass Valve (BPV)
So this is what it took me two days to come up with. What a VRV is? What an EFCA is? Still searching. But I have grown to hate acronyms because they can be for many things. Some sound like the same ball park. How would you like to go in and order an LSD (Limited Slip Differential) and get an sugar cube full of drugs? Why it can't be spelled out is beyond me.
Old 08-24-2010, 08:03 PM
tdcarter72's Avatar
ArdWrknTrk,
Thanks for the reply and the information. Now I know what I am looking at and looking for when reading these diagrams.
Old 10-03-2012, 12:41 PM
deere5103 deere5103 is offline
deere5103 is starting off with a positive reputation.
I need a 99 ford f150 vacuum routing diagram....thanks for the help
Old 10-21-2015, 12:53 PM
Building_Fords's Avatar
Building_Fords Building_Fords is offline
Building_Fords is starting off with a positive reputation.
87 F150 Emissions Diagram?
Hi All,
I am in the process of finishing putting my 87 F150 4.9L, REG Cab, 2WD back together...and I could REALLY use the Emissions Diagram, can you provide one, or tell me where to get it? Thanks!
Old 10-21-2015, 01:44 PM
Demonhawk Demonhawk is offline
Demonhawk is starting off with a positive reputation.
Quote:
Originally Posted by Building_Fords View Post
Hi All,
I believe Autozone may have the diagrams you need here: | Repair Guides | Vacuum Diagrams | Vacuum Diagrams | AutoZone.com
Vacuum line replacement on a 1987 4.9L straight six 87oldtimer 1987 - 1996 F150 & Larger F-Series Trucks 8 06-03-2014 07:02 PM
1984 E150 emission controls craig47 1968-2013 Full Size Vans 0 04-09-2012 10:13 PM
1977 Ford F150 Ranger w/ a 400 vacuum FordRanger77 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-10-2008 05:29 PM
Need a Vacuum Diagram for 89 5.8L with AT Hunt4Fun 1987 - 1996 F150 & Larger F-Series Trucks 7 08-24-2007 07:17 PM
vacuum hoses????where oh where do they go? DREW LESTER 1961 - 1966 F-100 & Larger F-Series Trucks 4 09-07-2006 05:26 AM
Tags
1983, 1987, 1998, 29, 50l, bronco, cyl, diagram, diagrams, f150, ford, lines, truck, vacum, vacume, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
