Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
  #1 (permalink)
Old 08-22-2010, 04:21 AM
_Rick_'s Avatar
_Rick_ _Rick_ is offline
Garage is empty, add now
_Rick_ is gaining momentum as a positive member of FTE.
Relays in under dash fuse box
Hi again folks,
I'm not very experienced with relays so I thought I should ask the question just in case.
Are all the relays supposed to be the same in the under dash fuse box?
301, 302, 303, 304, 305, 306, 307.
FOAB-14B192-AA
While dealing with issues on my truck I noticed excessivly loud clicking in relay 302 (Powertrain ECC) when I turn the ignition to ON and also when starting the engine.
With the ignition in the OFF position I pull the relay out and re-insert it and it activates what I think are other relays (1 under dash and 1 in the engine compartment).
I also tested it (302) in socket 301 (Front blower motor) and the blower stays running even with the key OFF.
I'm guessing the relay that was in socket 302 is bad unless I'm missing something obvious?
Thanks,
Rick...
__________________
______________________________
Shut up. Just shut up...You had me at "I like your truck"
------ (How-to Use The FTE Search Tool) ------
__________________________________________
.....'02/EphTreeFiddy/LarryAt/Six.Ate/CC/LB.....
Do I really need to add a smiley face to every sarcastic comment?
  #2 (permalink)
Old 08-23-2010, 10:01 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Wow, you're getting a WHOLE LOT of problems, aren't you?
Me thinks you need an EVTM (wiring diagram, pinouts, etc). I would look at my '01 service manual for you, but I think '02 is a bit different.
I looked in my '01, and it seems the PCM relay and the blower motor relay should be the same. They are labeled with standard Bosch relay pinouts, and look to be the same.
Pull the blower motor relay, and put it in place of the PCM relay, after making absolutely sure the pinouts and part numbers are the same, and see what happens.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
Tags
02, 2000, 2002, 302, 305, 306, clicking, dash, f0ab14b192aa, f150, f250, foab14b192aa, ford, relay, relays, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
