parking garage? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
parking garage?
Old 08-22-2010, 12:08 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
parking garage?
so today i'm following a '01ish lincoln navigator into a downtown parking garage that i knew i'd be going to. so insted of driving my excursion which i knew would not fit i took the expedition thinking i'd be fine.
so as the navigator goes under the first hanging bar it clears by about 1" so i figure i'm fine right? wrong. i hit both roof rack cross bars on the yellow hanging bar. i stopped and tryed to back down the ramp but there was allready 2 cars behind me so i figured worst case i'd remove the cross bars once i got inside. luckly i did not have to since the rest of the garage is slightly higher then bar at the enterance.
my '98 4x4 is all stock except has 265/75 16 tires insted of 255/70's.
anyone else had an issue with getting your expy in garage's? i never thought i'd have that issue with a stock expy. i need to double check the height on the garages i guess insted of thinking the smaller truck will just be ok lol
Old 08-23-2010, 08:10 PM
boeamos boeamos is offline
boeamos is starting off with a positive reputation.
ya when my Expy was stock i wacked the lifting arm at Atlanta Aquarium but the rest was ok
Old 08-23-2010, 10:37 PM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
They do sit fairly high. Mine actually sits higher than my dad's '99 Suburban 2500 4x4. I'm on either 265/75/17 or 265/70/17...can't remember. The roof rack doesn't exactly help the situation.
However, and this just may be me, I've always thought Navi tires looked a bit small. Maybe the stock tire was smaller than Expys?
Old 08-23-2010, 11:34 PM
AlaskanEx's Avatar
far as i've seen they have 265/70 17s on all i have seen. but somthing i didnt think about is they have the air ride which would/could make them it alittle lower.
Old 08-24-2010, 07:35 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
The Lincoln may have had air suspension, and the Navi tires may look smaller because the rims are bigger.
Old 08-25-2010, 06:18 PM
Totoro's Avatar
Totoro Totoro is offline
Totoro is starting off with a positive reputation.
Min clearance on my 03 is 6'6" (Spec is 77.6"). I think some of the 1st Gen Expys were a little taller 78.4 (2002) and some were shorter 76.6 (1999).
It also depends on how well they hang that clearance bar!!!
Old 08-26-2010, 03:01 PM
soundtransmission soundtransmission is offline
soundtransmission is starting off with a positive reputation.
One time I was pulling into a parking garage, late for a client meeting, and I barely knocked the maximum height bar (at 6'-2", I believe, maybe 6'-3"). Figuring that they hung the bar lower than what the garage could really take (because of numnuts like me), I went on in (plus, there were cars behind me). Sure enough, everytime I passed under a concrete beam, the car would get stuck -- not "stuck-stuck", but stuck snugly enough to where everytime I encountered a beam, I had to really lay on the gas pedal to jolt myself past it (the luggage rack was the culprit, so there was some give to it of course).
Here's the funny part (not at the time, though) -- after my meeting, I'm exiting the garage and drive up to the automatic teller to pay for parking. I pay the ticket, and the garage door opens in front me to let me out into the street. I start to go through the garage door BUT I had to go past one more concrete beam. I of course get suck, so I gun the pedal, get "unstuck", but the garage door (which must have been on a timer) closes on my hood as I'm exiting! The door goes back up when it senses that it had crushed something, and I drive out.
Long story short (I know, it's too late), I drove straight to 3 different body shops to get estimates, called my insurance company to tell them the story, and $2,500 later (picked up by the parking garage), I've got a new hood.
Moral of the story? If you touch the bar, in all liklihood your vehicle is too tall for the parking garage.
Old 08-26-2010, 05:15 PM
AlaskanEx's Avatar
i was worried somthing like that may have happend. luckly it didnt! thats a really crappy story lol glad you got it all taken care of though.
No reverse only? Radio and p/w intermittent. Camc 1999 - 2003 7.3L Power Stroke Diesel 0 01-12-2015 12:48 AM
Installed MY Posi-Lok cable I fish 1997-2006 Expedition & Navigator 2 08-04-2014 03:12 AM
anyone have a diagram of a 05-07 inst cluster? kengarchow 1999 to 2016 Super Duty 0 06-05-2014 01:13 AM
93 f150 c6 or c4 swap b-kipker 1987 - 1996 F150 & Larger F-Series Trucks 5 01-09-2012 04:34 AM
Install aftermarket radio...but have CanBus turn-on power...help Tylus Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 10-23-2010 03:56 PM
Tags
clearance, clearances, expedition, f150, f250, fit, ford, garage, garages, lincoln, navigator, parkign, parking, tall, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
