BYPASS FUEL SELECTOR SWITCH - Ford Truck Enthusiasts Forums
Old 08-21-2010, 10:00 PM
Rick Wallace Rick Wallace is offline
Rick Wallace is gaining momentum as a positive member of FTE.
Any body ever bypassed the FSS and let fuel draw from both tanks? Of course with an E-lectric fuel pump,and would the gauge be correct/
Old 08-21-2010, 10:06 PM
oldkountryboy's Avatar
oldkountryboy oldkountryboy is offline
oldkountryboy has a good reputation on FTE.oldkountryboy has a good reputation on FTE.oldkountryboy has a good reputation on FTE.
not sure how easy that would be to do, but i know the gauge would not be able to display both tanks at the same time
if you wanted to add another fuel gauge then you could have one for front and one for rear
Old 08-21-2010, 10:11 PM
poocher pup poocher pup is offline
poocher pup is starting off with a positive reputation.
you would be only reading for which ever tank you have switch on as to fuel level. don't know what it would do if one tank was empty and other had fuel if it would suck air from empty tank.
Ill have the bed off soon to fix the pick up tubes and replace fuel lines so it will be fairly easy to get to,once im done I dont want to have fuel problems again
Old 08-22-2010, 10:20 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
That would be the FSV (Fuel Selector Valve) not FSS (Fuel Shutoff Solenoid).
-Enjoy
fh : )_~
Old 08-22-2010, 10:28 AM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
if you draw off both tanks then your going to have some issues man. first, as stated your only going to be able to read off one tank. second, since you will be sucking more out of one tank then the other (it will never suck evenly) then when one tank runs out you will be sucking in air and that will get into your system. so its not worth the hassle. one think you could do ( i would if i were trying to get rid of the fsv) is remove the back tank, weld a bung to the front bottom side of the tank and weld a bung to the top passenger side of the front tank next to the pick-up setup. run a nipple and hose from the rear to the front with a ballvalve between the lines. you run just off the front tank, and when its empty just flip on the ball valve. it will fill your front tank and since its a smaller tank in the rear theres chance of overfilling. theres enough drop in there where it will drain the tank in about 10 min. you will just have to remove both caps so it doesnt get pressure in one and vacuum in the other. unless you run a second hose to it at the top of each tank for air transfer.
Old 08-22-2010, 12:36 PM
Quote:
-Enjoy
fh : )_~
Yea that thing
Old 08-22-2010, 12:52 PM
OK,,,X that idear,,,thanks
Old 08-22-2010, 10:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
For the very small amount of problems the FSV gives, I would not think about trying to run without one.
No way to tell how much fuel you have left in both tanks, no way to direct which tank the fuel is sucking from or returning to without it.
The one on my 86 is getting very close to 500,000 miles, still work perfectly.
Bypassing Fuel Selector Switch Erictusio 1967 - 1972 F-100 & Larger F-Series Trucks 6 02-13-2017 12:58 AM
Underhood Fuel Filter Bypass sgrol 6.7L Power Stroke Diesel 4 12-08-2016 08:26 PM
Bypassing front fuel tank on a 89 f150 jcowboy00 1987 - 1996 F150 & Larger F-Series Trucks 1 11-18-2014 03:11 PM
fuel inertia sw w craker 1987 - 1996 F150 & Larger F-Series Trucks 4 04-19-2013 08:35 AM
Electric fuel pump 6.9 IDI Skip1970 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 04-16-2012 04:27 PM
Tags
1990, 69, 86, air, bypass, diesel, f150, ford, fuel, fuelseletor, runs, selector, sucking, switch, tanks, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
