View Poll Results: do you want more threads like this?
yes, very helpful
100.00%
I really don't care
0%
no, I really don't care to see stuff like this
0%
no, this guy is an idiot
0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
How to replace a u-joint
remove the driveshaft, and take it to your big vise.
find a socket to fit inside where the cup goes, and squeeze lightly to remove the spring clip
remove from vise, and remove the spring clip
find a larger socket than the cup, but smaller than the driveshaft, place small socket on one side, large on the other, then squeeze it out with the vise, you may need a pipe for leverage. it will go crack twice, then it will shove the cap into the socket
place 1 cup in the drive shaft, turn the new joint in, make sure to face all u joints in the same direction, or they will bind. place 2nd cap on, and squeeze carefully with the vise, until the caps are flush with the outside
squeeze the cap in with the socket until you can see the slot where the spring clip goes, on both sides.
install new spring clips
install grease fitting
bolt it back in the truck, use blue loctite on the nuts to keep them from backing off.
[IMG]http://i620.photobucket.com/albums/tt282/dustybumpers
/94trans029.jpg[/IMG]
good luck, as you see, not a hard job, just take your time
You can also hit "PREVIEW POST" prior to posting it. That way you get to see how it's gonna look when you DO post it and if you don't like it, edit it.
You hit the "ENTER" button here in FTE, not in PhotoBucket. All you will see here is the URL to PhotoBucket. Hit the "ENTER" button as many times as spaces you want
dustybumpers
18
01-09-2021 01:09 PM
IDIDieselJohn
15
12-31-2011 03:16 AM
dustybumpers
Maryland Chapter
49
05-03-2011 08:54 PM
kashmcoll
24
01-26-2011 03:35 PM
IDIDieselJohn
34
12-11-2010 01:25 PM
