Replacing Rear Wheel Bearings - Broke Oil Slinger - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-21-2010, 06:32 PM
GregN's Avatar
GregN GregN is offline
GregN is gaining momentum as a positive member of FTE.
Unhappy Replacing Rear Wheel Bearings - Broke Oil Slinger
Well,
I decided to replace my rear wheel bearings today. Everything was going alright until I broke my oil slinger (the part that goes between the inner bearing and the hub seal - Part# F81Z4670AA). The Ford dealer is closed, and I won't be able to get a new one until Monday after work. Is there really a need for this little metal washer with bent over tabs? I read somewhere that this "Slinger" is to help keep the oil away from the seal, but I don't know.
I guess, what I am trying to do, is talk myself out of waiting and buying the Slinger, and just slap this thing back together tonight! What do you think?
Thanks,
Greg
Old 08-21-2010, 09:29 PM
DIXIEDOG1's Avatar
DIXIEDOG1 DIXIEDOG1 is offline
DIXIEDOG1 is gaining momentum as a positive member of FTE.DIXIEDOG1 is gaining momentum as a positive member of FTE.
If they didn't need it Ford wouldn't have put them in, the bean counters would have cut that corner already. I'd wait and put it back original
Old 08-22-2010, 09:52 AM
GregN's Avatar
Yeah, that is what I was thinking. The original one looks like it has a little wear on it, so I figured that it was doing something!
Thanks for not letting me cut corners Hopefully they will have one in stock on Monday.
9"progress and /??? underthebridgejim 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-15-2015 11:47 PM
1977 400 oil slinger? HVACTOM 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 03-31-2015 04:07 PM
5.4 Rear Crank Seal/Oil Slinger ExpyDude99 Modular V8 (4.6L, 5.4L) 4 07-15-2014 08:31 PM
rear hub won't go on ckalck 1999 to 2016 Super Duty 6 08-05-2013 08:18 PM
Timing Chain Question Bob Lawhorn Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 02-04-2005 02:34 PM
Tags
1996, 460, 73, axle, bearing, bearings, big, block, diesel, f250, oil, rear, replacing, slinger, superduty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
