My Edge Insight ! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
My Edge Insight !
Old 08-21-2010, 04:06 PM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
My Edge Insight !
Received it by UPS 2 Days ago, mounted it yesterday,,finally got the pics figured out on how to post them on FTE !
Mounted it through the ESOF dash panel,,,removes easy,,Replaceable,,no holes in the Dash,,,Plus a passenger can unhook it from the Velcro,,and pull it over to them closer,,so they can go through the Menu,,and get what ever Gauges we want,,,,so far I have only seen the EOT 8 degrees hotter the the ECT,,seems to hover 3-5 degrees hotter,,This Insight is SWEET !!
Old 08-21-2010, 06:39 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Congrats on your new toy. I really like mine.
Old 08-21-2010, 10:11 PM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
If you dont mind me askin, how much are those and are they easy to install?
Old 08-22-2010, 03:34 AM
As a previous post about the Edge Insight,,,was on sale at Amazon.com,,,$246 for the unit,,Plus I also purchased the turbo thermo-couple(not installed yet) for $80.
The Edge unit just plugs right into the OBD II port ,,below the dash,,about where the drivers right knee is,,,the Insight has so many parameters,,,like 2 gauge setup,,3, 4, 5, 6, 7, gauge setups,,,my son found and setup the EOT(engine oil temp) in the "Ford section",,that and the ECT (engine coolant temp) is the main reason I purchased it,,but tranny temp, and EGT's will be great to keep an eye on also,,,,Easiest gauge install ever!!
Old 08-22-2010, 07:45 AM
havns3's Avatar
havns3 havns3 is offline
havns3 is starting off with a positive reputation.
where you have yours mounted how did you get the plug to it? did you drill a hole through the dash panel?
Old 08-22-2010, 07:54 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Quote:
He stated "no holes in the dash", but I dont know how??
Old 08-22-2010, 08:05 AM
havns3's Avatar
Quote:
yep i read that too. maybe he means in the big part of the dash that spot where he mounted his is where my 4 wheel drive switch is at. maybe that is a seperate panel
Old 08-22-2010, 10:41 AM
Thats it guys,,,,That little panel pops out,,a small straight blade screw driver can slide right under it,,,I did have to drill a hole in that small removable ESOF switch panel,,,,But it is replaceable,,,a small aluminum angle comes with the Edge Insight,,double stick Tape, and the 2 pcs of velcro to mount it too the Aluminum angle.
One Note,,,it may not fit there if you have the ESOF 4x4 setup,,,I have the Manual T-case and shifter,,so my Dash plate was Empty!
You can always buy the $40 dollar mount for the Edge,,that mounts under your A-pillar on the Dash,,,,But as someone else mentioned,,,Is easy to see,,and Scum-Bag thieves are every where,,!!
Old 08-22-2010, 10:46 AM
sammy77's Avatar
Thats a great place to mount but I do have the 4x4 switch there...
Old 08-22-2010, 10:55 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Here is my dash mount. It matches the stock dash so well that I hope it blends in and won't attract too much attention.
Old 08-28-2010, 05:16 PM
havns3's Avatar
here is how i have mine mounted now well its not mounted it is just jammed between the dash and the windshield.
Old 06-01-2014, 08:15 PM
bfloyd4445 bfloyd4445 is offline
bfloyd4445 is starting off with a positive reputation.
Quote:
Yeah i really like mine and have been using it for 67 years.
I think I am about to get around to buying one of those Edge insights to moniter my FICM voltages very soon, Thanks everyone for the Edge comments
Added some More spikes...Pics! dvldog458 Excursion - King of SUVs 57 06-04-2015 10:48 AM
my 300 is missing Rogue_Wulff Ford Inline Six, 200, 250, 4.9L / 300 17 09-28-2014 11:41 AM
pic test Zeat User Gallery & Picture Display 0 10-21-2012 08:36 AM
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
56 F100 Project gquinn8516 Nebraska Chapter 110 04-15-2012 01:10 AM
Tags
01, 2003, 2005, 60, ct, diesel, edge, f250, f350, ford, insight, install, installation, manual, psd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
