Power Window Motor Repair - Ford Truck Enthusiasts Forums
Old 08-21-2010, 03:15 PM
WarOzz's Avatar
WarOzz WarOzz is offline
WarOzz is gaining momentum as a positive member of FTE.
Post Power Window Motor Repair
I decided to start a new post on my window motor repair, big thx to LCAM-01XA for his original post on how to fix broken dowles in the motor. Below I have outlined his post with my own photos and comments. My windows work awesome now!
Quote:
Originally Posted by LCAM-01XA View Post
What Syco said. Only may I add that you don't necessarily need to buy new dowels , instead you can use just regular 1/4" hex nuts - you need 6 per motor assembly, as you stack them two-high where there was a single dowel. The plastic dowels are a safety item, if the window glass meets high resistance when going up (such as while attempting to crush someone's arm or neck) the dowels will slip and prevent causing a serious injury to the victim. When you use steel nuts you lose this feature, the motor will keep moving the window till something breaks, and from my experience with this setup my bet would be the person's limb will give before the glass or the motor or the linkage - not a concern for me as I have a regular cab truck and no children or dogs who could get trapped by the window, but for people with crew-cab trucks this may potentially become an issue...
<br>
<br>
Remove door panel and speaker.<br>
<br>
<br>
Find dimple and notch locations.<br>
<br>
<br>
Drill holes with 1/2 drill bit, I drilled a smaller pilot hole first and then notch slot with grinder.<br>
<br>
<br>
Motor disasembled... note the pile of greasy broken plastic dowles on the left.<br>
<br>
<br>
Everything cleaned up and ready to put back together.<br>
<br>
<br>
Insert 2 1/4 nuts as shown then install gear to wedge assembly in place.<br>
<br>
<br>
This shows gear assembley with first 2 nuts installed.<br>
<br>
Use a screwdriver to push the remaining 4 nuts into place.<br>
<br>
<br>
This shows all 6 nuts and gears assembled and ready to go back into motor.<br>
<br>
<br>
I packed with grease and reassembled.<br>
<br>
<br>
Motor reinstalled and working perfect, notice the piece of duct tape I used over the ground out slot to protect wires from chaffing.<br>
Old 08-21-2010, 04:04 PM
Coalroller's Avatar
Coalroller Coalroller is offline
Coalroller is starting off with a positive reputation.
nice post warozz! the pictures along with LCAMs instructions will make for a perfect repair! also love the snap-on tools, great choice!
Old 08-21-2010, 05:08 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
Cool, cause I just put my door panels back on after running coax for the mirror-mount antennas, and only then realized I never took pics of where to drill and grind for the motors. And I should have also swapped my motor out too, oh well, some other day when it ain't raining (literally) on my parade...
Old 08-21-2010, 06:27 PM
WarOzz's Avatar
Thx guys, glad ya like. Snap On is about all I buy anymore when it comes to hand tools. I am always buying new tools for work and recycle the older ones home
Old 08-21-2010, 08:26 PM
Coalroller's Avatar
sounds like me, started out with all craftsman tools and tool box and top chest at work now that whole setup it settin in the garage with all new snap-on for work
Old 05-28-2011, 08:10 PM
cmack110 cmack110 is offline
cmack110 is starting off with a positive reputation.
Smile Power Window Motor Repair
Hey!! Thank you WarOzz!!
The instructions were perfect.
One of the best DIY experiences from the web I've had.
I just finished repairing the motor on my 1992 F-250.
I can't thank you enough!!
-cmack110
Old 05-28-2011, 08:40 PM
akamacgyver's Avatar
akamacgyver akamacgyver is offline
Clueless spectator!
akamacgyver has a good reputation on FTE.akamacgyver has a good reputation on FTE.
Plastic dowels
FYI guys,
I purchased replacement plastic dowels at autozone for 8 bucks. they are sold in sets of three and look like clear mini marshmellows. Windows are working great for 6 months now.
Old 05-28-2011, 10:32 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Good write up. I recently had to do this to both windows in my 86, greasy, chunky fun.
Old 05-29-2011, 02:09 AM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
I need to do this in my MIL's truck...
One thing to note, i'm told those plastic pins are a safety device to keep you from getting injured should you be stupid enough to roll the window up on your arm, leg, or neck (yea....i said stupid...). By fixing it with 1/4" nuts, you take away that safety feature, but guarantee you'll never have to replace broken plastic pins...
Your choice...
Old 05-31-2011, 04:41 PM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
38Chevy454 is starting off with a positive reputation.
Quote:
Originally Posted by akamacgyver View Post
FYI guys,
Six 1/4 nuts are about $.18 total. Either fix works, but the nuts will not break if you hit resistance and lose the safety feature thay provide. The nuts will also not get brittle and break which results in doing this repair a second time.
I did the 1/4 inch nuts repair on my truck, discovering on my own to use them. Working good for near 2 years now.
Old 11-04-2011, 04:22 PM
FionaFarmer's Avatar
FionaFarmer FionaFarmer is offline
FionaFarmer is starting off with a positive reputation.
Sweet write-up. Thanks so much. I just repaired the motor in my '88 in about an hour for less than $.50
Old 11-08-2011, 03:06 PM
drs1023 drs1023 is offline
drs1023 is starting off with a positive reputation.
I had to read it twice to catch the fact that you DID NOT remove the regulator assembly. I just replaced two regulators/motors on mine, and it seemed quicker to just remove the whole assembly to do this fix. Guess I was wrong. Nice DIY!!
Old 11-08-2011, 11:30 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
I've been doing some power window repairs lately, and have found that if needed the motor can be swapped without a lot of effort with the gear box from the opposite side too. As it stands now, I think I have 3 or 4 spare motors for windows! Helped I got some from the wreckers recently.....
Old 11-09-2011, 01:04 AM
SnuffthePunkz's Avatar
SnuffthePunkz SnuffthePunkz is offline
SnuffthePunkz is starting off with a positive reputation.
Damn, thanks for ressurecting this old thread, my windows have gone to crap when rolling up, was gonna just get a new motor, this could help.
Old 11-09-2011, 09:28 AM
If they are going up, but need help, it will either be the nylon pins have crapped out, or the motor is getting tired. Replacing the motor (if you are going new) will fix it, as the pins are part of that assembly. A used one, may have a good motor, but those pins could be not far from giving up too. I would take it apart and see if the pins are shot, if so, replace them, or replace them with the nuts, and run it a while.
I had one motor this fall that stopped all together, turned out that it was corroded between the motor housing and the gear housing and wasn't making good connection back to ground.
I'll try to expand on this thread in the next couple days and take some pics of the actual motor and gearbox guts.
1946-47 Mercury 5 Star 1947 and Older Ford Trucks 7 12-01-2012 10:41 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 01:02 PM
New Cold Air Intake & Fan Shroud WarOzz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 06-28-2010 01:32 PM
My 2009 F-150 Platinum morgan867 2009 - 2014 F150 56 01-01-2009 03:59 PM
Got My New Bull Bar Tylus 2004 - 2008 F150 17 10-11-2007 07:13 PM
Tags
1987, 1997, 1999, f150, f250, f350, fix, ford, grinding, motor, power, repair, truck, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
