Power Window Motor Repair
#31
Thanks a ton for the post Ed. I was online getting ready to order a motor when I ran across this. I already had 4 nuts so had to go get 2 more. Thanks for the pics too, a description would have never gotten through to me. Mine went out yesterday and it's fixed today. All I have left is to JB Weld a crack in Ford's sorry plastic door panel. Thanks again... best post I've ever dealt with.....Here's to ya....
#33
How short do they have to be to be shot and needing replaced? Mine were only 1/4" maybe 5/16" long. Motors seem to work OK when they do work. I replaced all the plastic pucks with ball bearings.
Should I have the motor brushes replaced? Is that all the guy who rebuilds motors and starters does? There is a local guy that I would take them to if it is a job best done by a pro. If it's only brushes I think I can do that.
I apparently have a bad switch as once in a while a window will not work. Usually if they go down they come back up except for Wednesday Had to pull panel and motor off regulator to raise window back up.
When I test my switch and find it bad what brand do I want to get? Is the Dorman brand working out OK or should I hunt down a factory switch. My switches look horrible anyway all cracked and weathered.
I only want to tear these door panels off one more time. I have other projects to do and finish.
#34
#37
windows motor
Hello WarOzz ,my name is Bruno i live in Brasil .
my truck uses this windows motors , i like your idea !
I used poxipol glue for repair a windows motor ,but the motor completely fixed to action the window for down he lock and not ascend more !
the because,i dont understand , can be windows machine problems or in the motor
now i bought 2 used windows machine with motors , but these i decided to copy the original. I used rubber for to make
I hope it works!
and sorry for my English, I am learning
I hope it works!
#38
I just used this method to repair my FS Bronco's driver window motor in a couple of hours on Saturday. Thank you Guys, thanks I used a wratcheting adjustable 8mm spanner on the one bolt, and the silly non-standard bolt in the motor with odd head I drilled the head, it then came out easiy. Then tapped a standard thread on there (5mm x something) and it was easy from there on out. One thing - I forgot about the circlip and slightly deformed the head of the shaft so I had to file it to get the gear mechanism off, bit otherwise plain sailing. I noticed the yellow pieces were in the worm drive too so lots of cleaning that out. Also re-sealed the cover.
EASY PEASY, and that nut fix ... without it, I'd be lost.
#39
Qustion about Transferring Window Regulators
Hello i was wondering if someone could shine some light on this topic for me, I own 1990 F-150 XLT , and wanted to transfer window regulators and panels to my 1991 F-250, Is this possible? Just wondered if Ford already installed the electrical pigtails in the door from the factory. Didn't wanna change the doors since i just had them painted on mt F-250, Any help would be greatly appreciated.
#40
depends the model of window machine ! but if is the same doors of your 1990 , is possible change !
#41
Yes i took a look , And there is no power for any accessories, Looks like i could change it over with no problem ,It looked like the holes are already drilled for the motor assy. But i would have to run power to the motors from one of the accessories power sources. And drill holes for door panel that has power windows and locks, Its a full door panel verses partial that's on there already.
#42
looking for a link
I know this is an old thread BUT
I've an '88 7.3 E350 with the window problem.
Just before Covid (2019) I went to start to replace the window motor. I found a youtube video showing drilling 3 holes to access the motor bolts, taking just the motor out, replacing it. Short and sweet.
So in late 2019 I drilled the holes, bought the motor, went on a short vacation to Mississippi from Virginia. Covid hit while we were down there, didn't return until about August this year.
Can't find the youtube link.
I do much better if I've got a video to stumble through a project.
Anyone know of the link or can help?
#43
The following users liked this post:
#44
williamwilliam
213
12-20-2020 03:20 AM
sofob0909
06-14-2016 02:50 PM
