1999 F150 4.6L Fuel Pressure Regulator - Ford Truck Enthusiasts Forums
Old 08-21-2010, 01:13 PM
jdberry1 jdberry1 is offline
jdberry1 is starting off with a positive reputation.
I need to replace the fuel pressure regulator on my 1999 F150 w/ 4.6 liter V8. Where is it located and any tips on replacing?
Old 08-21-2010, 03:26 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
It's located on the driver side fuel rail to the rear.
Could you tell us why you need to change it if you didnot know where it was?
Did someone tell you it needed to be changed and why?
Good luck.
Old 08-21-2010, 07:25 PM
The truck has been idling rough when I come to a stop or when it is in park. I had the parts store read the service engine codes and that is what came up. It seemed to make sense to me. What do you think?
Old 08-21-2010, 07:55 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
First thing is to change the fuel filter................
03 f150 4.6 wont start FUEL REGULATOR? Aggie05 1997 - 2003 F150 7 02-17-2015 09:37 PM
99SD Fuel Pressure Regulator Location??? caliaviation Modular V10 (6.8l) 4 05-28-2014 09:50 PM
cel codes gacrkr85 1997 - 2003 F150 10 01-01-2014 09:26 PM
1999 7.3 fuel pressure regulator jsavin 1999 to 2016 Super Duty 8 02-26-2013 09:26 PM
Fuel pressure regulator question LaReko 1997 - 2003 F150 4 01-13-2013 11:55 PM
Tags
04, 1986, 2004, 46, 46l, 99, f150, ford, fuel, location, pressure, recommended, reg, regulator, replace, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
