why are my batteries dead???????? - Ford Truck Enthusiasts Forums
Old 08-21-2010, 09:14 AM
worm5932's Avatar
worm5932 worm5932 is offline
worm5932 is starting off with a positive reputation.
just like it says!! both were replaced about 9 months ago. my truck sat in the driveway for 11 days untouched, the radar detector was plugged in. it sits like this all the time and this hasnt happened since the new batteries. is that enough to kill 2 batteries??? oh yeah, im leaving town in about an hour. i trust she'll take care of me!! maybe hope....
Old 08-21-2010, 09:34 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
What brand batteries?I have had Wal-Mart batteries go grave yard dead in 9-10 months
First I would have the batteries checked then if good try to find if there is a draw on them
My truck sits a couple weeks at the time with radar detector and GPS plugged in an never killed the batteries
Old 08-21-2010, 09:53 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
hey Ray i just bought a '98 Grand Cherokee laredo with a 4.0....how do like it???
are you sure its the batt's not a bad connection from sitting??
my trucks sits all winter and fires right up..but i un hook them when it gets parked ...
Old 08-21-2010, 11:25 AM
rbaker6336's Avatar
Quote:
Originally Posted by ron's power stroke View Post
hey Ray i just bought a '98 Grand Cherokee lerado with a 4.0....how do like it???
So far after a couple years (about 22k miles) I like it fairly well.Economical transportation (20 mph 24-26 hiway) and pretty trouble free except a bad ECM when I first bought it.Now has 133k miles
Old 08-21-2010, 11:57 AM
guitarpicr's Avatar
guitarpicr guitarpicr is online now
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Just something to check- A couple months back I came out after a couple weeks of not driving the old girl and batts were dead. Charged them & it started up. Later that evening I went out to check something and found the light in the glovebox was on. Door was just slightly hung up on my bag full of spare cps parts. No trouble since I cleaned out the glovebox a little bit.
Old 08-21-2010, 12:54 PM
itsjustdan26 itsjustdan26 is offline
itsjustdan26 is gaining momentum as a positive member of FTE.itsjustdan26 is gaining momentum as a positive member of FTE.
Any drain on a battery for a long period of time will drain your system. Even your radar detector will do it. Even an aftermarket anti-theft system will do the same thing. It needs to get the power some how. Luckly its an easy fix, just unplug your detector and keep on parkin. My truck sat for a few months w/o the batteries hooked up and I plugged them in and it fired right up. I have the NeverStarts from WalMart. They were in there when I got the truck.
Old 08-23-2010, 06:13 PM
worm5932's Avatar
So how do I go about finding out if I have a drain on the system. I know funding it won't be easy but first I need to know if there is actually a drain.
anybody use a battery buddy atuomatic disconnect switch? Ultraboy Excursion - King of SUVs 2 12-16-2013 10:16 AM
truck running on the battery 72camperspecial 1967 - 1972 F-100 & Larger F-Series Trucks 9 05-28-2013 10:12 PM
92 F-250 Dual Battery Knorske 1987 - 1996 F150 & Larger F-Series Trucks 7 06-16-2012 02:28 PM
I Want a GOOD Battery That FITS! LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 29 05-30-2012 12:35 PM
Ford factory dual battery holder RadarRick Electrical Systems/Wiring 3 04-28-2008 09:27 PM
Tags
2003, 60, 73, bateries, batteries, battery, bought, dead, diesel, draining, f250, f350, ford, powerstrke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
