Stroker Motor
08-20-2010, 11:22 PM
on
Stroker Motor
How do you take parts out of a 460 and put into a 429 and make a stroker motor?
08-21-2010, 12:27 AM
460 crank and pistons to work with your heads & deck height. (two or three possible for a 429). Rods are the same length.
Just like Ford did.
Serving suggestion: Instead of taking the 460 apart, just get the whole engine and start there.
08-21-2010, 01:05 AM
429 and 460 use the same block so they drop in.
There is an exception that is you can't put the 78 and early rotating assemblies into the D9TE blocks with out a LOT of clearencing.
bambam1987
10-31-2009 02:02 AM
Mtthwvn73
13
02-07-2006 08:09 AM
zach2004
08-14-2004 08:53 PM
pineguy
13
12-05-2002 01:23 AM
Bull
02-05-2002 12:04 AM
