Hi,i would like to know if a 351 out of a 78 van will swap into a 77 F250 4x4 400 4spd ,will the flywheel work or does one from a 460 work? or am i out of my mind!!!!!
which 351? if it is a 351w, than no, you will need other goodies to make it work, like a bell housing, etc... if it is a 351m/400, then it is bolt in if you have the rigt flywheel or pull the one off the old engine
