Transfer case fluid type - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-20-2010, 02:54 PM
bigred66's Avatar
bigred66 bigred66 is offline
bigred66 is starting off with a positive reputation.
I've got a 06' 4x4 with the automatic transmission and diesel engine. I went to ford today and bought some fluid for the transfer case. The guy at the counter gave me Motorcraft Mercon V fluid.
When looking online I found a video of a guy changing the transfercase fluid on a 6.0 and he was using "Mercon/Dexron III".
From a previous issue I had I know that Mercon V and Mercon/Dexron III are completly different fluids.
On the back of the Mercon V bottles that the ford guy sold my it says "Do Not Use In Transfer Cases."
Other forum posts I read just say to user Ford ATF.
So my question is, do i have the correct fluid ( Mercon V) for my transfer case?
Old 08-20-2010, 03:06 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Mercon III and Mercon V are completely different. As for transmissions, you can use the newer fluid in the older trucks, but not the older fluid in the newer trucks. If the bottles state to not use in transfer cases, I would return them and get the Mercon III or equivalent. I have no idea why III ATF is okay and V ATF is not. I changed the fluid in mine with Valvoline MaxLife Mercon/Dexron ATF.
Old 08-20-2010, 04:00 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Old 08-20-2010, 04:04 PM
bigred66's Avatar
Thanks for the responses guys. Where would we all be without forums?
Old 08-20-2010, 06:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
i just changed my 04's with mobil 1 atf truck seems smoother for some reason also. do know with 80k mine was real dirty so looks like once a year will be for now on
Old 08-20-2010, 08:30 PM
Ricson's Avatar
Ricson Ricson is offline
Ricson is starting off with a positive reputation.
I went through the same thing a few weeks ago. Went to my dealers parts counter and asked for 2 qts. transfer case fluid, Parts guy comes back with Mercon V fluid. So i tell the parts guy that i need transfer case fluid not Mercon V fluid. The parts guy says Mercon V is the correct fluid. Just then the tech that did my studs last month walks up, So i ask him if the Mercon V is correct, He said I'll check he comes back with a notebook computer looks it up on fords network and guess what, The correct fluid is transfer case fluid. I'm Not sure whats the difference in the fluids.
The parts guy didn't know ford had labeled transfer case fluid.
Old 08-20-2010, 08:38 PM
bucci's Avatar
bucci bucci is offline
bucci is gaining momentum as a positive member of FTE.bucci is gaining momentum as a positive member of FTE.
Quote:
That's the bad part. They should be trained to know. Afterall, it's not like you asked him about Chevy fluid for the transfer case.
Old 08-20-2010, 09:12 PM
Ricson's Avatar
The parts guy got a little upset and said he and can't access the same info. the techs can.
Old 08-20-2010, 09:16 PM
bucci's Avatar
Something's really wrong if the parts guy can't look up what fluid the transfer case takes.
It's not like you asked him for front end alignment specs or the backlash on the rear diff.
Old 08-20-2010, 09:34 PM
Ricson's Avatar
He did look it up and it says Mercon witch my book says too. But Ford doesn't have Mercon label any more so he came back with Mercon V. The tech was able to access the part number for the fluid witch was labeled as transfer case fluid, Witch i believe is reg old Mercon.
The parts guy said he couldn't access the same info. the tech did.
Old 08-21-2010, 04:38 AM
tonyv74 tonyv74 is offline
tonyv74 is starting off with a positive reputation.
I have a 2000 Excursion V10. I put Redline D4 ATF in my transfer case 7 years ago and change it every 50K miles. Before, when I put it in 4x4, the transfer case would make a slight woo'ing noise since it was new. The same with my old suburban before that. When I put the Redline D4, in just the first mile it was so quiet I couldn't tell if it was in 4x4. Even now with 205K miles it still runs just as quiet. Redline is a little expensive, but in my opinion $22 over the course of 2-3 years is chump change. I highly recommend it.
Mercon/Dexron III vs. Mercon V.... EMC V10 X 1999 to 2016 Super Duty 11 01-21-2011 10:59 AM
Quick Transmission/transfer case question bobbyrjw 1999 - 2003 7.3L Power Stroke Diesel 5 12-14-2010 10:42 AM
Dexron 6 trans fluid RGV10SD 1999 to 2016 Super Duty 5 12-01-2008 10:07 PM
OK to mix different specs and brands of ATF? dharget Oil & Lubrication 4 06-24-2008 10:13 AM
Valvoline Durablend Vs. Motorcraft ATF tnt4cat Oil & Lubrication 13 01-07-2005 08:25 AM
Tags
04, 2002, 2004, 73l, case, change, diesel, duty, explorer, f250, f350, fluid, super, transfer, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
