1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 Factory f250 SuperCrew Subwoofer
  #46
Old 01-22-2013, 08:11 PM
mikey350's Avatar
mikey350
mikey350 is offline
Originally Posted by bryced15
What did you end up doing for a remote wire?
Run a fuse tap in wire from the fuse box on the passenger side under the dash back to the amp, from fuse #44 I think, works great, no static, on power up.
  #47
Old 01-26-2013, 09:28 AM
_red rocket_'s Avatar
_red rocket_
_red rocket_ is offline
So, if I get this straight...
New 10 gauge fused wiring from the battery for an always hot power
New 10 gauge ground, short length
New 10 gauge from fuse block #44 (part of the upfitter switches)
Or are you guys using fuse #44 for both the AMP's remote and always hot connection?
I am finally going to get this done this weekend
thx
  #48
Old 01-26-2013, 09:52 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
thx
If 10 awg is the recommended gauge for your amp, then you only need that for the power/ground.
The amp's remote turn on can be smaller gauge. use #44 for amp turn on only! Also make sure that the fuse for your 12v constant is up near the battery.
  #49
Old 01-26-2013, 10:22 AM
_red rocket_
Much appreciated!
That is what I was leaning towards but wanted to hear from someone who did this already.
  #50
Old 01-26-2013, 12:46 PM
2000silverbullet
PM sent.
  #51
Old 02-27-2013, 09:09 PM
JohnnyThunder's Avatar
JohnnyThunder
JohnnyThunder is offline
I'm wanting to add the pac aoem-frd24 to my 2011 f350 lariat with the factory nav. Will this pac unit work with my setup?
Did you try the PAC unit? I sent PAC an email and this is what I got back from them as I have the factory nav as well.
Hello,
Unfortunately the AOEM-FRD24 would not be compatible in the 2011. You can use our SOEM-4 but it will need to be hardwired into the system. It is not plug and play. This would be the only option for this vehicle. Thank you.
Brian Miller Technical Advisor
AAMP of America
This is an email request submitted via the PAC Web Site to the Technical Support Department. Form data follows:
Message: Hi, I have a 2011 F250 Lariat with the factory nav and 9 speaker sound system. I would like to replace the main and sub amps and was wondering if the PAC AOEM-FRD24 would work for this, if not do you have a product that would work?
  #52
Old 03-02-2013, 11:09 PM
Isaac628's Avatar
Isaac628
Isaac628 is offline
Comp kickers
Hello everyone new member here. Just finished installing two kicker comp shallow mount 10's behind the rear seat of my 2011 f250 crew cab. I'm using an alpine mono block 800 watt amp at 2 omhs also using an audio control crossover it took a lot of work getting the box to fit and let me tell you it's a tight fit but still ended up with about an inch and a half of space between subs and back of seat. The only thing I didn't do is take pics of everything. I have never thought of running kickers and boy was I impressed these things rock plenty loud. Weather it's rap rock country or what ever it all sounds awesome I'm using a sealed box. Very very happy with my new rig.
txazguy
6.7L Power Stroke Diesel
05-08-2015 06:48 PM
txazguy
04-04-2015 03:48 PM
indy358
12-11-2014 08:44 PM
2011FX2Crazy
2009 - 2014 F150
05-08-2014 09:55 PM
kkey1
1997-2006 Expedition & Navigator
10-02-2012 09:45 PM
Quick Reply: 2011 Factory f250 SuperCrew Subwoofer
