38 gal Extra Capacity rear fuel tank - Ford Truck Enthusiasts Forums
Old 08-19-2010, 08:08 PM
1979F350/460's Avatar
1979F350/460 1979F350/460 is offline
1979F350/460 is starting off with a positive reputation.
Question 38 gal Extra Capacity rear fuel tank
I'm just curious to see if anyone has a picture of this tank mounted without the bed on the frame. I got a tank from work out of a new Ford E van chassis. The top half fit in the location but the bottom hangs down kinda low. I will get a picture tonight to show. Just wanted to get a idea of how far the extra cap tanks hangs down.
Thanks
Old 08-19-2010, 08:15 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Let's see a pic!
Logic tells me if it's twice the capacity then its gotta be twice as deep given the same horizontal space and it can't fit if its' taller.
Old 08-19-2010, 08:23 PM
cghstrojan08's Avatar
cghstrojan08 cghstrojan08 is offline
cghstrojan08 is starting off with a positive reputation.
Dont the trailer specials have them?
Old 08-19-2010, 08:49 PM
highoctane74's Avatar
highoctane74 highoctane74 is offline
highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.
not that good of a picture, hope it helps.
Old 08-19-2010, 08:54 PM
highoctane74 That's a good enough shot for me. I ran out to the garage and snapped some pics. Looks like the tank I have will be 7 to 8 inches below th bottom of the frame. I'll post the pics in a min.
Old 08-19-2010, 09:01 PM
Not sure how far mine is below the frame. It is a Spectre 38 Gallon though.
Old 08-19-2010, 09:02 PM
Top View
Passanger side view
Drivers side
from back of cab facing rear of the frame
Showing measurment
Let me know what you guys think. I have a 3 inch body lift for it and I planto do at least a 6" spring lift.
Old 08-19-2010, 11:40 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I'm gonna use a 33 gallon bronco tank and skidplate I got.
Old 08-20-2010, 01:47 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
That looks about right. Just make sure you can get your filler and breather hoses over the frame without pinching them too much.
Old 08-20-2010, 01:54 PM
I may just put a notch in the cross brace.
Old 08-20-2010, 03:41 PM
TECH51 TECH51 is offline
TECH51 is starting off with a positive reputation.
Quote:
I did the 38 gal tank in my 95 F350 CC DI 2yrs ago and love it. Now I'm doing it to my 76 F350 CC. BTW the Bronco 33 gal tank is deeper and come on 33 or 38 for the same $ new..
Old 08-20-2010, 03:54 PM
yeah, but someone offered me this one as a partial trade on some stuff I had so I took it. Its slightly shorter front to rear as well. For the low price of free I'm sure I'll find a way to make it work. I think if I just use the extended straps for the 38 gallon gallon tank it will fit, if not I may need to move the crossmember back a bit.
Old 08-20-2010, 04:12 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
It sure would be nice to drive my truck more than 100 miles on a tank. Where do you guys with the 33 & 38 gallons tanks put your spare tire? I have a 33 inch spare tire in my stock location below the fuel tank, was there when I bought the truck. I have had it out but put it back.
Old 08-20-2010, 04:15 PM
Quote:
I'm attempting on making this 40 gal work we will see how it go's! I will have to put the spare in the bed.
Old 08-20-2010, 04:44 PM
I've got 44's so there's no fitting a spare under the truck. I don't have a spare anyway.
depending on how the bronco tank goes I'll prolly put another one of those or the 38 gallon truck tank in my flatbed, and it doesn't have a spare either, but I may mount one on the headache rack or something.
67 gallon Titan fuel tank 03silverTJ 1999 to 2016 Super Duty 6 05-12-2016 02:34 AM
Rear fuel tank strap beersy50 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 10-11-2014 11:17 AM
1963 Econoline Gas Tank Installation ChopperJon Ranchero & 1961 - 1967 Econoline 3 12-04-2013 10:58 PM
Plastic Pull Handle hanging on Bottom of Diesel Fuel Tank ggadwa 6.7L Power Stroke Diesel 10 12-07-2012 12:20 PM
Excursion/extra fuel tanks usark9 Excursion - King of SUVs 1 10-15-2005 04:29 PM
Tags
38, 86, capacity, diagram, extra, f150, ford, fuel, gallon, gas, installation, tank, tanks, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
