38 gal Extra Capacity rear fuel tank - Page 2 - Ford Truck Enthusiasts Forums
Old 08-20-2010, 05:24 PM
Witty73's Avatar
Witty73 Witty73 is offline
Witty73 is gaining momentum as a positive member of FTE.
If you are going with a 3 body lift, I would be tempted to make, or simply modify the original mounting straps to cheat the tank up under the body a couple of more inches. I cant honestly think of any problem with that and I think it would help alleviate some of the filler tube headaches as well.
Old 09-01-2010, 08:22 PM
cpt7576 cpt7576 is offline
cpt7576 is starting off with a positive reputation.
Does spectra offer the correct ohm sending unit for the orginal guage? If so what Ohms did you order for your tank that works ,if you plan on using the orginal guage.
Bob
Old 09-05-2010, 08:22 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
I am asking the same thing ' CPT7576 ' ask.
Old 09-07-2010, 09:36 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
I'm told the bronco sender works and is deeper, or, you can keep your stock one, and with the relocation brackets it will just read "full" until youre down to half a tank.
Old 11-20-2013, 06:22 PM
757mech1 757mech1 is offline
757mech1 is starting off with a positive reputation.
Quote:
Originally Posted by 1979F350/460 View Post
Top View
Passanger side view
Drivers side
from back of cab facing rear of the frame
Showing measurment
Let me know what you guys think. I have a 3 inch body lift for it and I planto do at least a 6" spring lift.
I wish these photos were still up.....
Old 01-16-2014, 09:13 PM
bluebaby bluebaby is offline
bluebaby is starting off with a positive reputation.
Anyone have a link or idea of where to find the larger tank? I'm looking to put a flatbed on soon and would love to get the tank in first.
Old 01-16-2014, 10:53 PM
brokersteve's Avatar
brokersteve brokersteve is offline
brokersteve is starting off with a positive reputation.
Quote:
I tried the Bronco 33 gallon sending unit on my 38 gallon first. I was able to bend the tube enough to reach the bottom properly, so it was a great fit. Problem, as I found out later, is that the nipple end that the fuel line attaches to is bent 90 degrees, while the stock 19 gallon sender is about 22.5 degrees. I did not realize this when I reinstalled. Instead of routing the line over the crossmember, I had to go down between the sharp edge of the tank and the crossmember. This in short time cut through the fuel line. It didn't look right to me at the time, but figured I was crazy. Here is the stock 19 gallon sender:
And here is the 33 gallon Bronco:
Now, what I did worked great. Since the 33 gallon unit was a near perfect fit, I cut the barb tube off just before the elbow, and managed to get a small flare on the end to bite in to the hose. I hoped a flare tool would work, but the vice did not fit. I manually bent it out a bit. End result is great. I would definitely to this route again as opposed to trying to braze an extension on my stock sender, etc. This is a solid, one piece tube and the fuel gauge is pretty accurate.
67 gallon Titan fuel tank 03silverTJ 1999 to 2016 Super Duty 6 05-12-2016 02:34 AM
Rear fuel tank strap beersy50 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 10-11-2014 11:17 AM
1963 Econoline Gas Tank Installation ChopperJon Ranchero & 1961 - 1967 Econoline 3 12-04-2013 10:58 PM
Plastic Pull Handle hanging on Bottom of Diesel Fuel Tank ggadwa 6.7L Power Stroke Diesel 10 12-07-2012 12:20 PM
Excursion/extra fuel tanks usark9 Excursion - King of SUVs 1 10-15-2005 04:29 PM
Tags
38, 86, capacity, diagram, extra, f150, ford, fuel, gallon, gas, installation, tank, tanks, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
