anyone know how to read rearend tag?? - Ford Truck Enthusiasts Forums
Old 08-19-2010, 06:07 PM
myred's Avatar
myred myred is offline
myred is starting off with a positive reputation.
How do i go about and finding out what gearing i have in the rearend of my truck? does anyone know how to read the tags? I believe i have a 411 seems to be torqued low
Old 08-19-2010, 06:59 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
To my knowledge there are two ways as far as tags to tell. Folks will tell you all kinds of ways to mark your tires and the ground and count rotations of axle vs tires and yada yada yada. To me it ws easiest to just look at the tags and look at these charts.
First link-Go to your truck and look at the rear diff from the rear. There should be a tag bolted to it. There will be alphanumeric codes on it. Compare your code to the chart and see which it says. This link is compliments of Cuda_Jim.
Ford Rear Axle Assembly Identification - Page 10 - FORDification.com
Second, you can look in your driver's door jam at the white tag. the bottom lines will have a part that says "axle". Under the word axle there will be either a letter and number or two digit number. Compare it to the following compliments of diesel_brad of PSN.
39= 3.55
49= 3.55
69= 3.55
B9= 3.55 LS
C9= 3.55 LS
H4= 3.55 LS
H9= 3.55 LS
25= 4.10
35= 4.10
45= 4.10
65= 4.10
B5= 4.10 LS
C5= 4.10 LS
D5= 4.10 LS
F5= 4.10 LS
H5= 4.10 LS
Should you have opposing codes between the door and diff cover, go with the diff cover or do the mark and spin thing to verify. The door tag will only be accurate if the diff has not been changed. Like in parts truck I have a code on the door for 3.55 LS but the diff tag says 3.55 open diff.
Also, if you have near stock size tires or even slightly larger you can tell by rpms at 75 mph. 4.10s will have you right at 2500 rpms with an auto tranny and slightly higher with 5 speed. 3.55s will have you closer to 22-2300 IIRC with auto and again higher with 5 speed.
Hope that helps.
Old 08-19-2010, 07:08 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Very good info Jacob. Auto rpms with 3.55's are a little less than that (I think mine is about 2100).
Old 08-19-2010, 07:24 PM
redman84's Avatar
Quote:
Even better! Not my info. Just the messenger...
Old 08-19-2010, 08:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
If you can read the numbers on the tag.
Bottom line of numbers will start with .10 or .55.
That would show an open rear axle with 4.10 gears or 3.55 gears.
If you see L10 or L55, then you would have a traction lock limited slip, again 4.10 ratio or 3.55.
The 4 or 3 is actually under the bolt head.
The next set of numbers would be 10.2 which would indicate it has a 10.25" ring gear.
Top row and the last set on the bottom row are build numbers which I can not tell you what they all mean off the top of my head.
Old 12-18-2011, 05:09 PM
jamfu jamfu is offline
jamfu is starting off with a positive reputation.
Ford Rear Axle Assembly Identification - Page 13 - FORDification.com
rear end tags
Will Ferrel is probably the worst not funny "comedian" ever
Need help with vin I'd for 59f350 Jakesnake59 1957 - 1960 F100 & Larger F-Series Trucks 1 08-09-2014 11:13 AM
Need help decoding vin# Jakesnake59 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-08-2014 06:59 PM
Gear ratio question my 66 1987 - 1996 F150 & Larger F-Series Trucks 11 02-05-2014 05:45 PM
99 f350 7.3l 4x4 rearend diff fluid bubba_v2008 1999 to 2016 Super Duty 3 05-17-2011 03:22 PM
decoding rearend tag from 9" hello there Clutch, Transmission, Differential, Axle & Transfer Case 1 09-07-2002 09:12 PM
Tags
2007, axle, code, codes, door, end, f250, find, ford, identification, l55, read, reading, rear, tag, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
