replacement v band - Ford Truck Enthusiasts Forums
replacement v band
Old 08-19-2010, 06:16 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
replacement v band
this one is for 2.5" but its got deep groove.... think thats more of what i should get... just dont think it will get tight enough.
TURBO V-BAND CLAMP EXHAUST 2.5" FORD x2: eBay Motors (item 390227317996 end time Sep-16-10 14:29:54 PDT)
Old 08-19-2010, 10:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
I think option two looks better to me.
The groove looks to wide in the first one.
Old 08-19-2010, 10:40 PM
Coalroller's Avatar
Coalroller Coalroller is offline
Coalroller is starting off with a positive reputation.
Quote:
Originally Posted by oreocreaming View Post
by stretched do you mean your down pipe wont fully tighten up to the outlet housing... itll spin and feel kinda loose? cause thats how mine is
Old 08-19-2010, 11:27 PM
Quote:
yep. it clamps til both sides touch and the clamp still spins and the elbow and downpipe dont fit snug enough. im thinking of trying to maybe make a gasket or something. i used to have sheet of lead. it would have made a perfect gasket but i ditched it. i knew i should have kept it.... damn
Old 08-20-2010, 04:59 PM
Coalroller's Avatar
thats what always happens you keep something for a long time thinkin you are gonna use it... then you dont and through it away and next day shoulda kept it... yeah mine does the same thing and i also have of black depositsof smoke on the firewall from where i guess its leakin out from between the where the down pipe meets the outlet
Old 08-20-2010, 05:59 PM
ya, its the dumps. and i just ran out of welding wire..... 1 hr drive to get more so im gonna wait til another day. screw it lol. im spraying my manifolds, up pipe and cross pipe with 2000 degree ceramic paint and wrapping the cross pipe with header wrap. got new gaskets too. want this to be the last time ive gotta take this stuff off until i get that damn 6.9l built.
Old 08-20-2010, 11:04 PM
Coalroller's Avatar
did you pull the manifolds to pain or did you just spray it in there and hope for the best coverage? also how rusted "stuck" were your bolts that bolt the cross pipe and up pipe?
Old 08-21-2010, 01:19 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Soak the header wrap in ceramic paint and wrap while wet ...
-Enjoy
fh : )_~
Old 08-21-2010, 01:57 AM
i pulled everything off to spray it. figured i wanted to replace all the gaskets too. i sprayed the cross pipe in ceramic paint, wrapped it then sprayed it heavy with the paint. got about 5 coats on everything.
93 Rebuild with a 95 4.0L OHV Short Block ThorM465 Ranger & B-Series 24 07-28-2016 04:34 PM
turbo upgrade Fireman_dave Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 01-02-2015 10:44 AM
Pacesetter vs OBX longtube headers Plowboy34 1987 - 1996 F150 & Larger F-Series Trucks 2 09-30-2014 10:52 AM
Tags
1996, 2001, 3, 73, 73l, areostar, band, clamp, clamps, exhaustcross, f250, f350, ford, pipe, powerstroke, replacement, turbo, vband, wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
