1998 F150 LOSS OF POWER
Old 08-19-2010, 04:48 PM
robjs111's Avatar
robjs111
robjs111 is offline
My 98 F150 with 4.6 4 x 2 just has started to act up, loosing power. When I press pedal down engine starts to miss, run like crap and loss power. What can it be?? 145xxx k miles but always ran great. Fuel pump, coils, plug wires I think are all original so should they be changed?? How can I test components?? What do you think?
Thanks.
Old 08-19-2010, 07:23 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Not enough to go on.
At the mileage, you need to put plugs in, inspect the boots, replace the fuel filter.
Then we talk about what you have left.
Codes, specificlly how it acts etc.
Otherwise we are shooting in the dark.
Old 08-19-2010, 08:42 PM
robjs111's Avatar
robjs111
robjs111 is offline
Check engine on, Po306. Changed plugs about a month ago, autolite. Also changed furl filter.
P0306 plugs, wires fuel pump, coils, vacuum leak, injector fault. Yikes where did I start?
Thanks.
Old 08-20-2010, 12:01 AM
robjs111's Avatar
robjs111
robjs111 is offline
Well pulled plug # 6, really wet and rusty? Funny just installed 1 month ago. Cleaned and reinstalled. Runs great. How did plug exterior get wet, etc?? Also should I replace coils, wires still??
Thanks for all your help.
Rob
Old 08-20-2010, 12:03 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
If you still have your owners manual, look at the scheduled maintenance, then bring it all up to speed. If the truck still runs like crap, then you can move on with diagnostics, but chances are pretty good that some TLC will fix the issue.
I would throw a couple ideas in, except you need to do the above first so this can be narrowed down, otherwise we all can produce a very long and potentially confusing list.
Old 08-20-2010, 12:18 AM
robjs111's Avatar
robjs111
robjs111 is offline
What ideas do you have?
Thanks.
dp1181
07-31-2017 09:10 PM
sonboy44
Modular V8 (4.6L, 5.4L)
06-07-2017 06:27 PM
lamm72
02-25-2017 07:55 PM
Dutch602
1997 - 2003 F150
07-31-2016 02:20 AM
gblaz123
17
11-10-2015 05:25 PM
Quick Reply: 1998 F150 LOSS OF POWER
