new to the FE world
new to the FE world
Just picked up a FE390 from my buddy. Came out of a 73 ford 4x4 towtruck. I want to install this in my 78F25. I will also post this in the engine swap forum, just have some questions about durabilty. I want to use the truck for plowing and pulling so I think the 390 will work well. Just may have questions when the puild is going on thanks.
Scott
Scott
the engine in he 78 was a 460 swapped for the 400 guy kept the engine, he has about 10 trucks 4x4's and 2wd, plust 20 engines all 360 390 351M400'S the wrecker had a 390 swapped into it, still working the deal on the engine and all parts to complete the swap along with the ford factory flatbed off his 67 250 2dw
Sorry to butt in but I am new to FE as well and was looking aroung this forum. I am pulling a FE out of my project It was mated to a 4 speed which I am keeping for the re-build and have a manual trans bellhousing. I'm not putting an FE engine back in, I'm trying to find info on the FE I have, I want to sell it but want to be able to tell people what it is. I found a 352 stamped on the front but is there anything else I need to know?
Get the date code off the block, looking from underneath its just below where the oil filter goes, it starts with a number and looks like 7A19 or something like that. Also get the casting code off the heads, its inbetween the center exhaust ports, just pull the wires and you can see it, should be something like ca8e-h, with those numbers and knowing if it was factory 4 or 2 bbl carb I can atleast tell you what they put models it came in.
kaden78ford390
11-10-2015 08:48 AM
truckjunky87
12-16-2004 05:29 PM
