Diag Help Needed for Danny(Mongo75)
Got a call from Danny a minute ago who is having some issues, and I told him I would post up so you guys could start looking at it. He had the truck shut off on him while towing and he is in a small town in the middle of BFE. When he got out and checked he noticed almost no coolant in radiator and it was coming out his CCV mod hose as well. Pulled dipstick, oil was milky and a bit over full.
He is going to try and have it towed to a dealer about an hour away but wants to see if he can get a head start on the issue so he doesn't get bent over. So far all I can come up with is a massive oil cooler failure allowing the coolant to be pushed into the oil passage. Anyone else have some ideas for him?
thats was my first guess as well
where is he located? any RHN members nearby
Oil cooler would have been my first guess too. Plus that's the easiest and cheapest suspect to check out first.
The problem of course is how much damage was done running oil/coolant mix in the crankcase. A compression check may be in order here. It doesn't take long for an engine to wear the rings and score the cylinders when coolant gets in the oil.
He doesn't have a smartphone so I am waiting for him to text me so I can look it up for him and see.
Clay,
Being that the oil pressure is greater than the coolant pressure, wouldn't it be more likely that the oil would go into the cooling system. I don't see how the coolant would get into the crankcase if the oil cooler was the problem. Wouldn't a leaking head gasket of a crack somewhere be more likely. Just food for thought.
Edit: Shawn beat me to it
Clay,
I think we may all learn something on this one, but I wish it wasn't at Danny expense.
I am wondering if it might be a scour problem behind the water pump. Danny has an e99, and if the sca's were not kept up with, then his water pump may have pumped all the coolant into the oil passages.
I have rebuilt a couple of oil coolers, and while I am not disagreeing with that diagnosis, the only thing I can figure about it would be that the first o-ring just completley let go.
