Misfire #3, PO 303 & 316 - Ford Truck Enthusiasts Forums
Old 08-19-2010, 07:22 AM
UB267 UB267 is offline
UB267 is starting off with a positive reputation.
My 2002 F150 4.2L used to be my primary vehicle, but I just switched & started to park it in my barn. It gets used at least once a week, if not more. Engine was running well until about a week ago. Runs very rough under load and idle is rough. My tester shows codes 303 & 316. After searching the forums (great stuff here!) I have replace the coil pack, wires & plug on #3 with no results. Last night I cleaned the EGR ports, but no luck there. That leads me to believe it's an injector problem, but not certain. Once I get above 2,000 RPM it seems to smooth out. Am I on the right track here? Also, is it possible to remove the #3 injector without tearing off the air intake plenum?
Thanks in advance for any help!
Old 08-21-2010, 12:34 PM
Question Now really confused
I've been trying to narrow this down for a week now! Guess the truck is upset that it's not #1 anymore.
Reset the codes & drove it a short distance. CEL comes back on & the new codes are 316 & 302! Sure enough, no spark on #2 only. Then tried the following:
Changed plug wire twice=no spark
Changed plug three times=no spark
Tested resistance to terminal right next to #2 on coil pack (the one that fires with it) & shows OK (that terminal is firing strong)
Tested the old coil pack to verify that it was bad=it was
Does anybody have any ideas? I can't make any sense of this.
Thanks,
UB
Old 08-23-2010, 03:13 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Yeah, confusing ?? alright.
Any chance you have 2 bad coil packs?
From what I read:
original coil pack = no fire on #3.
new coil pack = no fire on #2.
Could you put the original back in and see if the problem with #2 clears and problem with #3 returns?
Sounds like you know what you are doing as far as checking things. Keep us posted.
Old 08-24-2010, 10:24 AM
Problem Solved
Took off the new coil pack & took it back for a replacement. The new one works fine. Lots of time invested trying to figure this out when it was a faulty new part! Thanks for the suggestion Brian, you were right on.
Old 08-24-2010, 09:13 PM
BrianA's Avatar
Hey, even a blind squirrel finds an acorn every now and then.
Glad you got it squared away!
55 F100 & 46 F1 WncLee 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-20-2016 09:19 PM
Replacing Hard Brake Lines 1/4 or 3/16? Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-20-2013 11:44 PM
PO303, 306, 316 Ranger 2014 3.0 wmmarks Ranger & B-Series 9 08-08-2013 06:47 PM
po316 and po306 esecs 1997 - 2003 F150 10 01-30-2013 04:48 AM
2004 Ford F-150 Engine Shudder ApachePete 2004 - 2008 F150 4 11-07-2011 11:59 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2003, 303, 316, 38, 3o3, code, codigo, cop, engine, escape, f150, ford, misfire, po, po303
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
