Can't Scan Sirius Channels
I have a 2007 Expedition with the factory Sirius headunit. Everything was working fine until a few days ago. Now I can't change the channels off of the presets (using the "scan" buttons). When I try, it goes only to channels 213 or 214. When I cycle through the menus, I can't change it off the "category" mode. Any help is appreciated!
I know this one, hit the menu key (round button on the right) next to the display. The first item that comes up is SAT MENU, Hit OK and then use the side arrows to go to Category. Hit OK and use the up and down arrows to select the category you would like to scan through. I leave it open to ALL CATAGORIES.
Sorry, but that doesn't work for me. I dont have an "OK" to hit on my radio. When I get to the category view and press the up or down arrows, the choices are "Save Song", Delete Song, Delete All, etc.
I've had this happen before, but can't remember how to fix it. It's terrible to get old!!
TSB 08-5-1
03/17/08
SATELLITE DIGITAL AUDIO RECEIVER SYSTEM
(SDARS), MAY NOT SEEK ALL SIRIUS SATELLITE
RADIO CHANNELS
FORD:
2008 Focus, Fusion, Mustang, Taurus X,
Taurus, Edge, Escape Hybrid, Escape,
Expedition, Explorer Sport Trac, Explorer,
F-150, F-150, F-Super Duty
LINCOLN:
2008 MKZ, Mark LT, MKX, Navigator
MERCURY:
2008 Milan, Sable, Mariner Hybrid, Mariner, Mountaineer
ISSUE
Some 2008 Ford, Lincoln and Mercury vehicles equipped with Satellite Digital Audio Receiver System (SDARS) may not seek or be able to toggle through all channels in Sirius Satellite Radio mode.
ACTION
To correct this situation, set the Satellite Categories to ALL using the following instructions for the system installed in the vehicle.
SERVICE PROCEDURE
Navigation Radios
1. Press the SR button on the Radio Screen until SAT1 appears.
2. Once SAT1 appears press the Genre button so that the Category list appears. Select the Category All button.
3. Press the SR button on the Radio Screen until SAT2 appears.
4. Once SAT2 appears press the Genre button so that the Category list appears. Select the Category All button.
5. Press the SR button on the Radio Screen until SAT3 appears.
6. Once SAT3 appears press the Genre button so that the Category list appears. Select the Category All button.
You have now reset the category setting for each satellite radio mode.
Non-Navigation Radios With Built In Display
1. Press and cycle the Aux button on the Radio until SAT1 appears.
2. Once SAT1 appears press and cycle the Menu button until Category appears, Press OK.
3. The next prompt will be Category All, Press OK.
4. Press and cycle the Aux button until SAT2 appears, once SAT2 appears press and cycle the Menu button until Category appears. Press OK.
5. The next prompt will be Category All, Press OK.
6. Press and cycle the Aux button until SAT3 appears, once SAT3 appears press and cycle the Menu button until Category appears Press OK.
7. The next prompt will be Category All, Press OK.
Non-Nav Radios With External/Remote Display
1. Press the Sirius button on the Radio until SAT1 appears.
2. Once SAT1 appears press the CAT/Fold button so that the CAT icon goes away.
3. Press the Sirius button on the Radio until SAT2 appears.
4. Once SAT2 appears press the CAT/Fold button so that the CAT icon goes away.
5. Press the Sirius button on the Radio until SAT3 appears.
6. Once SAT3 appears press the CAT/Fold button so that the CAT icon goes away.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT080501 Claim Labor As Actual Actual
Time Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
18C851 42
03/17/08
RADIO CHANNELS
FORD:
LINCOLN:
MERCURY:
ISSUE
ACTION
SERVICE PROCEDURE
Navigation Radios
Time Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
18C851 42
