You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hi, I am working on a Mazda b2300 with a 2.3l four cylinder and an automatic transmission. I am installing a new engine and have forgotten which way that thin plate between the engine and transmission goes. Could someone please help me out with this. There is a groove in the plate so I assume that it does matter. There is also ford and a part number stamped on one side. Which way does this go?
I believe it's asymmetric, so it should only fit one way. Here's a pic of the back of a 2.3 block, notice the bottom bolt on the right sits higher than the bottom bolt on the left. The block plate should be the same way:
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
