steering wheel reclocking
Take it back to the shop and tell them what the problem is. They should and can, fix it. If the alignment was done correctly the steering wheel won't be off. Not sure if you can reclock the steering shaft with the rack & pinion shaft. Some have a master spline that needs to be lined up to be assembled. This may also apply to reclocking the steering wheel on the column. Plus if you were able to do that, you may loose turning radius in one direction or the other, depending on which way you turn it. Try to work with the shop that did the alignment or find another one.
NMFirstF2504X4
30
02-05-2013 07:57 PM
airharley
04-30-2008 03:08 PM
Knarf0486
2004 - 2008 F150
04-18-2007 07:36 AM
f100beatertruck
Electrical Systems/Wiring
01-04-2006 05:12 PM
