Old F-150 - Ford Truck Enthusiasts Forums
Old F-150
Old 08-18-2010, 08:05 PM
Old F-150 Old F-150 is offline
Old F-150 is starting off with a positive reputation.
Old F-150
Ok all you Ford goers, Let's see if some one can help me with what might be wrong with my old pickem up, I have a 1985 F-150, 5.0L/302 w/AOD trans. Just put on new headers and exhaust, wires, plugs, rotor & cap, new carb. Even with the old stuff on, the truck would not go over 65 MPH and with the new stuff it still does't. So I took it to the shop and they disconnected the electrical connections to the carb and advanced the timing and adjusted the carb. It runs better, but I still bearly get to 70 MPH after that. Is there any thing I can do to get it running faster on the highway? Oh I am also only getting about 8 MPG, I should be getting at least 12 - 15 MPG. Well there it is, if any one can help Please let me know.
Old 08-18-2010, 08:27 PM
Buckeye Rich Buckeye Rich is offline
Buckeye Rich is starting off with a positive reputation.
Fuel filter?
Put a fuel pressure gauge on it and drive it, see what the fuel pressure does?
Old 08-18-2010, 08:39 PM
Greyf100's Avatar
Greyf100 Greyf100 is offline
Greyf100 is gaining momentum as a positive member of FTE.
hows the oil breather look? is it dripping?
new air filter?
pcv?
whats timing set to?
idle ok?
is it just running out of power? what RPMS?
what size tire? what gears?
Old 08-19-2010, 11:37 AM
Hey guys thanks for reply's, I do have a new fuel filter, when I took it to a shop out here they said I was getting plenty of pressure and volume. I do have a new air & breather filters & PCV. Now the breather filter does have some oil on it. As far as timing the shop set it, he said he advanced it a little, how much I don't know. Tires, I have 31 x 10.50 - 15's, Gears in it I have no idea.
Old 08-19-2010, 11:45 AM
Dimitri.c Dimitri.c is offline
Dimitri.c is starting off with a positive reputation.
do you have a tach. If so what does it read at 65 mph. if not install an aftermarket one. I have basically the same set up. I don't think I've ever taken it over 65 any how.
Also there's a gear id tag on face of your rear diff held in by on of the bolts. Might have to shine it up a bit to tell....
-Dimitri
Old 08-19-2010, 11:49 AM
Thanks, I think I will get a tach, and I will look for that tag. Also does this truck have a ECM (Electronic Control module)? A computer.
Old 08-20-2010, 01:32 AM
gotjeepzj gotjeepzj is offline
gotjeepzj is starting off with a positive reputation.
My buddies chevy did this once but it was worse. It wouldn't go over 45 mph. He replaced the heads with some reman ones and all was good. Also check your cat it may be clogged.
Old 08-20-2010, 02:42 AM
Nope no problem with exhaust brand new, new headers, pipes, cats, mufflers.
Old 08-20-2010, 10:13 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
Does your distributor have a place for a vacuum line? If it does, you do not have a computer.
Old 08-20-2010, 11:30 AM
Nope no vacuum lines. Electronic ignition, Now where is the dawg gone thing, I looked everywhere. Some one said that it would be on the passenger side kick panel, couldn't find it there. Any help?
Old 08-20-2010, 03:13 PM
Franklin2's Avatar
Sometimes the computer is located right over the hump area under the dash. I am not sure what setup you have, since starting sometime in 85 I believe they went to fuel injection on the 302.
Old 08-20-2010, 03:25 PM
Old Hickory's Avatar
Old Hickory Old Hickory is offline
Old Hickory is gaining momentum as a positive member of FTE.Old Hickory is gaining momentum as a positive member of FTE.
You mentioned you put on a new carb. What kind of carb is it?
Old 08-20-2010, 03:27 PM
Yea they had both carbs & FI I have a 2bbl Stock
Old 08-20-2010, 05:42 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
I've seen them on the firewall,and under the seat on the floor.
Old 08-20-2010, 06:16 PM
Well it looks like I've got a lot of places to start looking. Not on the firewall or in the engine compartment, so I guess I'll look under the dash area.
My economic 390 project 0ldman 1973 - 1979 F-100 & Larger F-Series Trucks 29 07-07-2014 10:32 PM
vacuum easttexas Ford Inline Six, 200, 250, 4.9L / 300 12 08-11-2013 01:35 PM
EFI to carb conversion Rico47635 Ford Inline Six, 200, 250, 4.9L / 300 11 01-20-2011 12:46 PM
vv carb please God help me scooter1986 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 08-18-2006 12:10 AM
83 f100 timing advance greasyandclueless 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 12-04-2003 05:14 PM
Tags
f150, ford, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
