you can do them if not too bad. floor panel patch panels are available, usually about $20 per side. you can cut out the rusty spots, then pop rivet, or weld in the new panels. paint them top, and bottom, then under coat everything, good as new
study where the cab mounts are. make sure to spot weld the floor to the top of them, and try to use the cover for it over again. the new floor pans don't have the hole for the mount stamped in. if your covers are no good, use the ones from the parts truck.
well i got the donor fender put on old blue but i think the radiator support is bent too because i cant get anymore adjustment out the fender or hood and they wont quite line up
hey JR im looking for a set of rims for old blue the old rusted wheels aint cuttin it no more and i like the 92-96 wheels but cant find any anybody know where i can find some f150 rims??
