How do I get my MAIN dash out - Ford Truck Enthusiasts Forums
Old 08-18-2010, 03:51 PM
wolfrace's Avatar
wolfrace wolfrace is offline
You like apples?
wolfrace is starting off with a positive reputation.
So I have every bolt out and my main dash is "floating' and I can get it back enough to get at the rattle I need to fix. Feels like it is hanging up on something maybe the defrost vents. Anyone ever do this ...................... I need some help.
Old 08-18-2010, 04:02 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
i would like to know also.
Old 08-18-2010, 04:26 PM
wolfrace's Avatar
You like apples?
Me too, I about 2 seconds from taking rep saw to dash top and using a molded dash cover, to cover it up...............
Old 08-18-2010, 04:50 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Quote:
wolfrace PM me your e-mail address I have something I thank will help you out but it is in a word doc. And I don't know how to post it.
Old 08-18-2010, 04:52 PM
erbilabuc erbilabuc is offline
erbilabuc is starting off with a positive reputation.
I just took mine out last week. Do you have glove box out? the drink tray out? radio doesnt have to come out but it helps.Did you disconnect the instrument panel? Besides that the only thing I can remember that gave me trouble were the 2 bolts that are hidden by the dash piece that goes around instrument panel and extends radio area.
Old 08-18-2010, 04:54 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
There are two bolts above the radio.
Old 08-18-2010, 04:57 PM
wolfrace's Avatar
You like apples?
I have the light switch panel, stereo / instrument cluster panel out, the 650 dash panel out, glove box out, all other bolts including the defrost bolts out, (also the air bag bolts out (thoughs don't need to come out LOL)) the full dash is floating I just can't remove it.
PM sent richard.......................................
Old 08-18-2010, 05:10 PM
Deluxe06's Avatar
4000 rounds a min
wolfrace,
e-mail sent
Old 08-18-2010, 05:21 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Same here. Pm me.. I might also have something to take a peak at.
Old 08-18-2010, 05:44 PM
wolfrace's Avatar
You like apples?
Thank Richard that is a great file, I am noe looking to get the rest of the dash out. The piece that goes from the windshield to floor and from driver side to passenger side.
Old 08-18-2010, 06:41 PM
Deluxe06's Avatar
4000 rounds a min
Wish I could help you out there never went that far. When you get it figured out post a howto with pics. Would like to know my self if i ever need to.
Old 08-18-2010, 08:19 PM
wolfrace's Avatar
You like apples?
Reps sent, Soooooooooooo I won't be able to explain the rest............................... I FOUND MY RATTLE it was the trans fluid filler tube against the cab easy fix and I made a huge job otta it........................................... DOH!!!!!!
Old 08-18-2010, 08:36 PM
Deluxe06's Avatar
4000 rounds a min
Glad you found your problem and got it fixed. Kindda the hard way but still got it fixed. Thanks for the reps
Old 08-18-2010, 08:57 PM
danskool's Avatar
Go Bills !
Good job.. I know how you feel.. I had to track down a clunking. took me awhile and i almost had my rear passenger door off its hinges.. Found it was the jack under the rear seat clunking. Easier fix than almost ripping out the dash..
Old 08-18-2010, 09:36 PM
Smokiesman's Avatar
Smokiesman Smokiesman is offline
Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.
I once had a buzzing sound coming from under my dash that just drove me freaking nuts!!! It was only at certian RPMS. I finally gave up went over to my small local dealer and talked to some guys there! There peeked and pulled on stuff and finally hit the jackpot ! A brake line was just touching the firewall a little tug away and all was well in my world again!!
Smokie
Column vs Dash key. Pros and Cons? clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 10-19-2014 05:13 PM
window regulator rivet size and type GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 2 10-04-2014 10:48 PM
Dash lights don't work mzbh 1999 to 2016 Super Duty 1 08-24-2014 08:49 PM
80-86 Dash Parts kennyray 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 05-18-2014 02:06 PM
Fuel Selector Valve maddogjohnson 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-26-2012 10:29 AM
Tags
1999, 2000, buzzing, coming, dash, driver, f150, f250, f350, ford, instrument, panel, powerstroke, raddle, remove, side, sound
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
