351W clutch Z-bar - Ford Truck Enthusiasts Forums
351W clutch Z-bar
Old 08-17-2010, 10:11 PM
mudder460's Avatar
mudder460 mudder460 is offline
mudder460 is gaining momentum as a positive member of FTE.
351W clutch Z-bar
I am getting ready to drop a 351w in place of my 300. I have a np435. Now I need to know for anyone who has done this swap if I can reuse the z-bar from the 300 or do I need one from a 351m? Or are they the same size? I know I will need the pivot ball bracket that mounts to the bellhousing as well. I just need to know so I can get all my parts at one shot.
Old 08-17-2010, 11:55 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Z-bar is the same for all 73-79 trucks, as well as the frame mounted pivot.
Engine side bracket will need to be sourced from a 302.
Josh
Old 08-18-2010, 01:11 AM
mudder460's Avatar
Ok, that makes the z-bar easy enough. I thought the engine side bracket was the same for all as well?
Old 08-18-2010, 11:07 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
I've never done the swap but it seems to me like the engine side bracket from a 300 would also work with a 351 since the bell housing bolt pattern is the same. Kind of like I reused the engine side bracket from my 351m with the 460- same bell housing.
Old 08-18-2010, 07:01 PM
Bullitt390's Avatar
There isn't an engine side 300 bracket per se', it's really just a bolt that screws into the side. Whereas the other engines have an actual bracket to hold the pivot ball.
That was the factory set-up, I guess someone could have done something funky with the truck in the last 30+ years.
Josh
Old 08-18-2010, 10:26 PM
mudder460's Avatar
Yeah, it is just screwed into the side of the block. Some of the older 351w blocks were set up the same way till the 70's...iirc I guess I will just get the bracket and find out for sure! lol
Old 08-18-2010, 11:22 PM
Bullitt390's Avatar
The 289 engines had a stud pivot exactly like the 300 I-6, however, the 302 truck engines used a bracket (7A572 prefix)
Josh
Old 08-19-2010, 02:57 AM
mudder460's Avatar
Thanks, I will see what I can find.
1963 F-100 Clutch Z-bar Piviot Broken prestondave 1961 - 1966 F-100 & Larger F-Series Trucks 12 10-27-2012 09:34 PM
Zbar question 76_100 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-08-2012 03:46 PM
390 zbar bellhousing bracket 73f250kid 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-26-2012 06:35 PM
Clutch linkage ATC Crazy 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-27-2010 08:45 PM
1989 351w to a NP435 77custom408 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 08-01-2009 01:21 PM
Tags
351m, 351w, 460, ball, bar, block, clutch, f100, ford, motor, np435, pivot, small, speed, zbar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
