2011+ 6.2 Exhaust - Page 3 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 11-21-2014, 07:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
2011+ 6.2 Exhaust
  #31
Old 04-26-2012, 12:06 AM
TimRobillard TimRobillard is offline
TimRobillard is starting off with a positive reputation.
Exclamation 2012 F-250 exhaust
Research this endeavor carefully.There are definitely issues when installing a custom exhaust system on a 2011 or 2012 F-250 Super Duty with the 6.2 gas engine. I just had a Flowmaster 53073 70 series installed. Not good. There is barely any noticeable difference in sound, it's mostly just a droning sound. This was after jury-rigging the rear outlet to fit correctly. The inlet/outlet on the 53073 is 3 inches. The inlet is correct, and will attach easily. The outlet will not. The outlet to the tailpipe is 3 and 1/2 inches. Flowmaster mentioned this little tidbit after the fact. Nice of them to let me know. Flowmaster does not sell this muffler, or any other muffler for this vehicle with the correct outlet. You will need an adapter, unfortunately, there is very little room to do this. The option I used was to just weld in the gap. That worked quite well. A good welder will make it look stock. The biggest issue, by far, is the resonator. Because of this big lump of useless metal, there are no true "cat-back" systems available, no matter what you read, or what the manufacturer tells you. You will have to remove the resonator to get to a true cat-back installation. Here's the bitch part. The resonator has dual inlets, and a single outlet. This is one tricky part to bypass. My mechanic could not believe his own eyes. That was a first. This has been my experience. The one thing I do know is that no matter what you put behind the resonator, you will not get the results you are looking for. The resonator has to go. I'm currently researching a way to do this without hacking the hell out of my system. Possibly a dual inlet, single outlet bypass pipe ? Any ideas ?
  #32
Old 04-26-2012, 12:20 AM
Thumbs down No easy, bolt-on way.
It's gonna cost you ! The resonator is a huge hinderance. Read my post.
  #33
Old 04-26-2012, 08:02 PM
Gary Atsma Gary Atsma is offline
Gary Atsma is gaining momentum as a positive member of FTE.
The ideal way to go would have been to cut the pipes going INTO the front resonator, then running dual pipes from there into Flowmaster #530513, a dual 3" inlet muffler with a 3-1/2" outlet, which would make for a VERY clean setup, allowing you to weld the stock tailpipe to the muffler without "booger-welds". Should sound decent, too. One should always look at the ENTIRE catalog to know what all is available, then think outside the box when figuring out a system that will not only work, but work well. The main expenses here are the muffler and (2) lengths of 3" tube to connect the headpipes to the muffler. This system should pretty efficient.
  #34
Old 04-27-2012, 07:22 PM
I'm on it ! I was just trying to get better sound without going crazy. It's a brand new truck. Thanks ! I'll let my pride heal for a while, then tackle that.
  #35
Old 04-27-2012, 10:08 PM
Glad I could help! I think.....(Receiving free advice hurt your pride? New to me...)
  #36
Old 04-29-2012, 01:08 PM
Details Details !
Not really. I have a very obsessive personality. I researched the hell out of this, but it seems like every time I do, there's just one or two major details that are overlooked. It just kills me how Flowmaster, Borla, etc. all claim to have a cat-back system for this vehicle, when in reality, they don't. The devil is in the details. I find that every single time, without fail, there are litttle minor details that are overlooked. These details are what kill me. Take, for example, the AFE cold air intake part # 54-11972. This part has fittings in the plenum intake tube for replacing the crankcase vent lines. The Airaid cold air intake, part # 401-273 does not have these fittings. Which is correct ? They both claim to fit my vehicle, yet, they are different. It's these details that kill me. But, I do thank you for your help. It just gets so dam frustrating !
  #37
Old 04-29-2012, 03:43 PM
Well, the reason some air intake kits don't include as many parts as others, is that they don't need them, as they reuse existing parts.
Other kits have more parts because they fit differently enough to warrant them for a better fit.
The only thing cat-back really means is that the system does not start at the manifold, but at some point after the converters. In the case of the Ford F-250, that means the first clamp joint available is that behind the forward resonator. Evereything between the converters and the end of that resonator is welded from the factory for ease of assembly. None of this is a plot or conspiracy to foil anybody. In the case of air intakes, find the one you like, buy it, install it with any parts included PLUS any original parts needed, and you will be happy. You will still get EVERYTHING required to complete the job. Some just use more original parts than others. It's a matter of how each kit is designed.
In the case of exhaust systems, what is available are ALL better than the factory setup, but none are perfect because a certain amount of assembly ease must be figured in, and that would be a lot tougher if they had to make a kit that bolts to the rear of the converters instead of in back of the first resonator. To get that last degree of improvement, one must do a bit of "rolling one's own" at the local muffler shop, any of which can easily do what I described in my previous post.
So take it a little easier, do your homework on finding the right parts(read the WHOLE catalog) and try not to be so obsessive, since you DO know how you are. Best of luck in your future endeavors!
  #38
Old 05-30-2012, 09:42 PM
The Zar The Zar is offline
The Zar is starting off with a positive reputation.
  #39
Old 05-30-2012, 10:22 PM
  #40
Old 06-04-2012, 05:49 PM
akbash akbash is offline
akbash is starting off with a positive reputation.
Well, who's going first?
  #41
Old 06-04-2012, 05:56 PM
Quote:
Waddayamean?
  #42
Old 06-04-2012, 08:47 PM
Baja Daze's Avatar
Baja Daze Baja Daze is offline
Baja Daze is starting off with a positive reputation.
LOL...I've been waiting and wondering the same thing.
I'm about ready to pull the trigger on exhaust, but am undecided. I like the looks and simplicity of the Flowmaster system I mentioned earlier, but with so many other choices out there, I was hoping to hear some more sounds clips from others.
That dynomax system above looks great, except for one little thing...I'd prefer dual outlets out the rear.
  #43
Old 06-05-2012, 12:15 AM
Quote:
as I'd prefer dual outlets out the rear.
(Like how I did that?;-) Here's an idea for you- cut off the first resonator at the inlet pipes, then continue those pipes to a dual-inlet/dual outlet Flowmaster going into twin tailpipes that end wherever you like. Any good muffler shop should be able to handle this, plus it should sound GOOOOD!
  #44
Old 06-06-2012, 11:14 PM
stutzismydog stutzismydog is offline
stutzismydog is starting off with a positive reputation.
That dynomax system above would be great if it had dual in and dual out. I'd prefer dual outlets out the rear exiting on the same right side 3" apart and to the end of the bumper. Looks like all that Dynomax would need to do is build the dual inlet / dual outlet muffler.
  #45
Old 07-02-2012, 07:42 PM
08streetglide 08streetglide is offline
08streetglide is starting off with a positive reputation.
Ok, first off, i'm a long time visitor of this forum, new as a member. love it, have gotten lots of great info and help from it. I followed this thread and found that link to the dynomax exhaust. I already had installed the mbrp exhaust from the large resinator and back to a single exit. sounded ok, but wanted more. Didn't want to buy the complete dynomax system so called them to find out if I could just get the y pipe to eliminate the LARGE resinator. answer was yes and any auto parts store that carries walker or dynomax exhaust will have it or get it quick. So I got it, installed it with a reducer from 4" to the 3" going into the mbrp muffler. sounds AWESOME!!!!!! have had it on for about a month now, but here is the problem I am finding......I've lost 2 miles per gallon and have noticed a significant loss of power!! I'm going to assume its due to a lack of back pressure? too free flowing for a gas engine?? any thoughts on this?
Thanks,
Gary
Truck bed Jhiles62 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-02-2016 09:28 AM
6.7 drivers, how is the 6.2? tom18287 6.7L Power Stroke Diesel 25 04-08-2015 07:37 AM
6.2 Worker brandon.edwards 6.2L V8 1 07-02-2014 09:25 AM
Drove a 6.2L Raptor Today` Boss9F100 2010 - 2014 Ford SVT F150 Raptor 88 09-24-2010 11:45 AM
62 F250 Options jasonst 1961 - 1966 F-100 & Larger F-Series Trucks 11 01-01-2010 11:41 PM
Tags
2011, 62, 62l, back, cat, dual, exaust, exha, exhaust, f150, f250, ford, systems, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
