Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
1998 - 2001 5.0L 302ci Ford Explorer Drivers Side Cast Iron Exhaust Manifold
Old 08-17-2010, 02:56 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
CLICK ON THE LINK BELOW FOR CURRENT PRICES
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
This Manifold fits trucks built AFTER February 1998. This cast iron manifold has been designed to eliminate the faults of the original Ford design. Specifications
LH Driver's side
2 bolt flange
Corrosion resistant
Replaces original manifolds that are cracked from thermal expansion and contraction
Strengthened and redesigned in the vulnerable areas of failure
Note: For 1998 production vehicles: You can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
Now you can buy a high quality exhaust manifold so REPLACE your broken, warped, or cracked one now with this great fitting, alternative.
It is built to strict quality control standards and is a great replacement.
Backed by manufacturer's limited LIFETIME warranty. For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
BUY A NEW EXHAUST MANIFOLD HERE
1Aauto
10-20-2011 03:04 PM
1Aauto
07-05-2010 01:35 PM
Quick Reply: 1998 - 2001 5.0L 302ci Ford Explorer Drivers Side Cast Iron Exhaust Manifold
