Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vendor Specials, Discounts, Product Announcements & Group Buys
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
  #1 (permalink)
Old 08-17-2010, 02:56 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
Garage is empty, add now
1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.
1998 - 2001 5.0L 302ci Ford Explorer Drivers Side Cast Iron Exhaust Manifold
CLICK ON THE LINK BELOW FOR CURRENT PRICES
Click the image to open in full size.
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
This Manifold fits trucks built AFTER February 1998. This cast iron manifold has been designed to eliminate the faults of the original Ford design. Specifications
LH Driver's side
2 bolt flange
Corrosion resistant
Replaces original manifolds that are cracked from thermal expansion and contraction
Strengthened and redesigned in the vulnerable areas of failure
Note: For 1998 production vehicles: You can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
Now you can buy a high quality exhaust manifold so REPLACE your broken, warped, or cracked one now with this great fitting, alternative.
It is built to strict quality control standards and is a great replacement.
Backed by manufacturer's limited LIFETIME warranty. For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
BUY A NEW EXHAUST MANIFOLD HERE
__________________
GREAT SELECTION OF TOW MIRRORS
Tony
1A Auto Parts
CALL ME DIRECT1-866-403-3393
Shop For: Ford Truck Parts
Tags
2001, 50, bolt, broken, cracked, driver, exhaust, explorer, ford, gasket, install, manifold, replace, side, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
