1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No high beams
Old 08-17-2010, 10:46 AM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
No high beams
My truck only has low beams. When you move the stalk on the colum backwords it changes nothing, when you move it forwards the low beams go out but the high beams do not come on.
Before I change the $60 switch, is there anything else it could be?
Old 08-17-2010, 11:13 AM
fireman28's Avatar
fireman28
fireman28 is offline
You could have bad bulbs. Highbeams may have burned out on both at the same time or pretty close to the same time.
Old 08-17-2010, 02:23 PM
thomabb's Avatar
thomabb
thomabb is offline
The "flash-to-pass" position on the multifunction switch lights the high beam elements without turning off the low beam elements. The switch is likely not the problem based on your description. Check the bulbs and fuses. I don't mean to overstate the obvious, but sometimes the obvious gets overlooked.
What are the details of your truck? Someone may have a wiring diagram they can post.
Old 08-17-2010, 04:57 PM
bill11012's Avatar
bill11012
I did not know that the " flash to pass" position left them on. In that case then I need to check everything else before changing the switch. Thanks.
Old 08-21-2010, 12:58 PM
bill11012's Avatar
bill11012
Ok, well, I think I need the switch still.
I get power to the light on low beam but not on high, and when I switch it back and forth from high to low to high again it sounds like the contactor is messed up inside. Not the normal noise I am used to them making. Any Ideas before I drop $96 on one?
Thanks
Old 08-25-2010, 04:10 PM
bill11012's Avatar
bill11012
New switch did not fix it. Any ideas?
Old 08-25-2010, 04:57 PM
cdrmotorsports's Avatar
cdrmotorsports
cdrmotorsports is offline
You've double checked the fuses, correct?
Old 08-25-2010, 05:25 PM
bill11012's Avatar
bill11012
And then I triple checked them. Which fuse is used for high beams? I can start there and trace the wires.
Old 08-25-2010, 09:15 PM
cdrmotorsports
It should be listed in the manual. I don't know about Fords, but my old Chevy truck has the left and right highbeam on different fuses.
Old 08-25-2010, 09:20 PM
GUNNERDOG's Avatar
GUNNERDOG
GUNNERDOG is offline
What are your truck spec's? I have some wiring diagrams for 2002 - 2004.
Old 08-25-2010, 09:40 PM
bill11012's Avatar
bill11012
PO did not give me the owners manual.
Thanks.
Its an 01 XL, manuel trans, manuel 4x4, super cab V10.
Old 08-25-2010, 09:53 PM
djanzen's Avatar
djanzen
djanzen is offline
pull your steering column apart and check the wiring into the switch. there is a zip tie on the wiring harness an inch or two back from the switch, sometimes it is to tight and pulls on the connector at the switch (like my truck and pulls the harness out ) it made my high beams not work, when i found it it had almost caught on fire, all burnt fixed it up and have not had a problem in four years.
Old 08-25-2010, 09:55 PM
GUNNERDOG's Avatar
GUNNERDOG
OK, here are the drawings i think you need... but they are for a 2002 sorry.
Old 08-25-2010, 10:02 PM
bill11012's Avatar
bill11012
Thanks and reps to both of you. I will take that info and try and get this taken care of in the morning. I'll post back with what I find.
Old 08-25-2010, 10:03 PM
GUNNERDOG's Avatar
GUNNERDOG
Does your high beam indicator light come on? If not, check fuse 30.
EDIT: Thanks for the reps man!
Quick Reply: No high beams
