Simple Question about Oil Sender
Ross:
I would be interested in what you find as I have the same issue. When doing the rebuild on the flathead, my mechanical gauge would read about 50 psi at a decent rpm. I purchased a replacement oil sender (original one was crushed) and the gauge on the dash now nevers makes it quite to the 30 mark. I attributed the difference to the oil sender and the accuracy of the dash gauge.
If you find a new oil sender that improves the accuracy against the mechanical gauge, let me know!
thanks
Fred
thanks
Fred
Just food for thought: If your engine has been sitting for a while and is frozen up the there is a chance there is or has been some moisture in your oil.
The sender is an electrical device and so it is electrostatically active. That means if you have any moisture in the oil at all that sender is going to attract it and may rust inside. There's probably a higher possibility of that than being plugged with gunk!
Thanks guys for all the suggestions. And YES the truck had been sitting since at least 1991 and not even turned over. And I'm not so sure if it was really driven much before that. And yes the sender is on that filter T. Julie, I'd say you are right about the sender being corroded. I'll be swapping it out shortly.
