Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-16-2010, 06:29 PM
pathology knight pathology knight is offline
Garage is empty, add now
pathology knight is starting off with a positive reputation.
ACC wire?
i got one of those navitouch systems on ebay and am having a heck of a time with it.
right now, the biggest issue is the cd/dvd reader won't turn off when you turn the car off. It will only turn off if you manually turn the unit off. this is causing the battery to drain if you forget about it.
the manufacture said the problem is becuase of the cannbus system. Basically, they're no help.
i'm thinking that the way it's hooked up now, it's getting a 12v+ somewhere that won't allow it to shut off. Is there a ACC wire somewhere that i can hook up to this to turn it on/off with the car?
(2007 expy)
thanks.
  #2 (permalink)
Old 08-17-2010, 11:35 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Yeah, someone wired it wrong. It' should have a separate power wire that is connected to a 12v accessory wire that tells it to turn off when the truck is off. Did you install it? What wire harness kit did you use?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
2001, 2010, acc, accesory, accessory, battery, davidson, drain, expedition, f150, ford, harley, navitouch, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
