You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So I took the plunge and bought a 7.3 powered truck the other day, I have wanted one for a while, and now I have this object that I understand almost nothing on, as I have spent most of my years forcing air into gas jobs, not oil burners. I am interested in chipping it in the future, but I guess I should get most of the little problems fixed first.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
First off The tires are large, and the spedo is off by at least 10 mph or so. Does anyone in the area of Raleigh, Clayton or Fuquay have a Autoenginuity setup that could help me out with this little problem?
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs,E4OD,4.10 gears, K&N air filter,Hayden 679 trans. cooler,PSD oil filter,coolant filter and vac. operated heater shut off valve, manual glowplugs,Autometer water temp.,trans. temp., and pyro in three guage pillar pod, Autometer mechanical oil pressure under dash with twin vac/boost guages,TruxPort tonneau cover,straight piped,189,000 miles and counting. 88 Ranger 2.0, 5 speed,147,000 mi.,bought new.NC Chapter Member,IUE Retired, NRA Life Member,USMC.
Thank you, I ended up talking with some one at Autoenginuity yesterday, and it sounds as if its not going to help anyway. So I guess I'm off to find another solution to the problem. They said they dont offer any support for a 550 class truck, and they are maxed out with factory tire size options.<o></o>
<o></o>
The truck is a 2000 F-550 with a lift and 37" tires, I would like to get the spedo fixed prior to chipping it, or driving it for that mater. It looks as if the only option at this point is a superlift box unless someone else has an idea on how to get my problem resolved? I have talked to several shops and many have different opinions on how to fix it, but in the end none of the options I have been given will work. I guess I need to post something under the heavy truck section and see if I can get some answers.
Brian, WELCOME to FTE, glad you found the NC chapter! Im not much help on that thing but Im SURE some of the guys in the 7.3 or possibly even the superduty section could give you the help your needing.
I would LOVE too see some pics of a 550 with 37's If you get time post some up or put some in your gallery!
Scott
__________________ -Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
Okay, old thread, but I just joined the forum and found the NC chapter. I've got an AE setup but it's just a code reader. I'm not sure what you're in need of. I'm in Sanford.
Welcome to FTE! An AE is alot more then a code reader, especially with the enhanced packages.
SOLD 2-28-11.....
Thanks guys! I ended up solving the problem with a superlift box. I was thinking that we could solve my spedo and shift point problems with a scanner, but i guess the F-550's are different from the 250's and 350's and they dont make a AE that will work on them?? (Thats what the guy at AE said?) I'm sure some of it would work but they told me that most of the features wouldnt work on my truck. I also figured out that the tire size is limited to the factory aval. sizes, so that was out as a fix any way. Thanks again for all the help...
Thanks guys! I ended up solving the problem with a superlift box. I was thinking that we could solve my spedo and shift point problems with a scanner, but i guess the F-550's are different from the 250's and 350's and they dont make a AE that will work on them?? (Thats what the guy at AE said?) I'm sure some of it would work but they told me that most of the features wouldnt work on my truck. I also figured out later that the tire size is limited to the factory aval. sizes, so that was out as a fix any way. Thanks again for all the help...
