Debris left in cylinder after broken plug removal-Did I screw up? - Ford Truck Enthusiasts Forums
Old 08-16-2010, 01:14 PM
Mainer86 Mainer86 is offline
Mainer86 is starting off with a positive reputation.
This weekend I changed the plugs for the first time on my 2005 5.4 after 120,000 miles. Followed the guidlines in the TSB to get the plugs out. I had two break off. I had the Lisle Ford Broken Spark Plug Remover LIS 65600 on hand. The tool worked great accept when pushing the ceramic insert down into the sleeve it caused a small piece of the side electrode to break off and go into the cylinder. Nothing else went into the cylinder. I attempted to get the piece out with a magnet and then with a vacuum. No luck with the magnet and not sure if the vacuum was successful (no borescope). At the time I didn't think such a small piece of debris would be a big deal and got comfortable running the engine anyway. I've put probably about 30 miles with no problem. Now after giving it more thought I'm very worried that I may have screwed up by not being sure to get the small piece of metal out. The metal piece was a small thin portion of the lower electrode, probably 3/16th long by 1/16th wide. It was quite thin (~1/32) due to 120,000 miles on the plugs. I know the best thing would have been to have no debris what so ever. Did I screw up? Would I have seen a problem already if I was going to? Or is this something that will cause damage over time? Anything that I can do now to avoid any future damage? Thanks for any input you may have.
Old 08-16-2010, 06:38 PM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Well it sounds like you did due diligence with regard to getting it out. So, I doubt you will have any lingering impacts. The possible side effects would be scratching the cylinder wall and/or the piece getting stuck to a valve causing compression problems. More than likely you got it with the vacuum and have nothing to worry about.
Old 08-16-2010, 08:04 PM
boots6868 boots6868 is offline
boots6868 is starting off with a positive reputation.
my guess would be if it were in there it probably isnt any more. the first time your engine fired that baby was blown out the exhaust like a tornado. one time on a carburetated motor i inadvertantly got my shop rag sucked in the intake that baby was gone before i could blink my eye. i think your probably good.
Old 08-16-2010, 08:58 PM
That is what I was picturing...the cylinder wall getting chewed up. Having it get blasted out the exhaust sounds great. Thanks for the input.
Old 08-16-2010, 10:10 PM
GwarForAll1021's Avatar
GwarForAll1021 GwarForAll1021 is offline
GwarForAll1021 is starting off with a positive reputation.
i did the same thing.
talked to a life time race mechanic for a local drag team. he said even tho porcelain is harder than steel, its fragile and will break up on any movement of the cylinder. damage if any will be minimal. a grain of sand will do way more damage...
blow out the cylinder as best as you can. use a stick with HEAVY grease on it to pick up some of the junk. clean it out with some WD40 then start that bad rascal.
Old 08-17-2010, 06:52 AM
The debris was actually metal. It was part of the lower electrode that is the very bottom of the spark plug, and on the motocraft OE plug, goes from one side to the other. Hopefully it got out of there and isn't doing any damage.
#8 5.4 Cylinder COP/Plug Change JWA 1968-2013 Full Size Vans 5 10-03-2016 08:56 PM
v10 plug change using impact hughjazz 1999 to 2016 Super Duty 16 09-09-2012 10:48 PM
Some tips on changing those nasty breaking plugs - 2006 Expedition 3V 5.4L sfc2001 Expedition & Navigator 44 07-10-2011 08:14 PM
Results-Changed out Pass. side phaser/plugs... rferoni 2004 - 2008 F150 2 01-19-2010 10:16 PM
Camshaft Position Sensor/96 Ranger 3.0 scottson 3.0L V6 4 09-19-2009 09:44 AM
Tags
54, borescope, broken, cyclinder, cyl, cylinder, damage, debris, engine, f150, hole, left, piece, plug, porcelain, small, spark, vacuuming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
