my latest project: Cowl Induction - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-15-2011, 06:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Originally Posted by Scratcher View Post
I'm still not convinced that water isn't going to get into the intake using the cowl in the event of the drain holes becoming blocking with dirt and debris. Isn't their even the slightest risk of water collecting in this area and getting sucked into the intake?
not really.
the cowl is so deep,that both drain plugs on each side would need to be plugged up solid,followed by a major down pour,even then it would take a long,long time to fill up the cowl so deep with water.i don't feel it's possible.
should you try this yourself,all will become clear about how little concern this is.
i couldn't begin to fill the cowl with a garden hose,it drains so quickly.
the hole you cut, is up a few inches from the bottom of the cowl,making the duct an air inlet only,rather than a possible water drain.
as far as water entering as "mist" as you drive down the road in rain,this doesn't appear to happen at all either,as iv inspected the ducting in such conditions and found it to be bone dry inside.
im going to say the possibility of this,would likely be higher with a custom ram air ducting than the cowl duct because your driving directing into the rain,and there's no issue with that either as far as iv read.
the cowl appears to be a very safe place to grab the high pressure air from,from my experience.
  #47
Old 01-15-2011, 06:11 PM
Scratcher's Avatar
Scratcher Scratcher is offline
Scratcher is gaining momentum as a positive member of FTE.
I might just do that. I' m pulling my motor this summer anyway so it will be easier to work in their with a cutter
  #48
Old 01-15-2011, 08:02 PM
oh its very easy to get too no matter what.
hypermax sells the kit for those interested:
Hypermax - Catalog
i just thought the price was kinda high for what it was,so i made my own.
  #49
Old 01-15-2011, 08:48 PM
Scratcher's Avatar
Dont see the point buying a kit for $88 when i can cut a hole and push the duct through
  #50
Old 04-02-2011, 09:12 PM
The_Josh_Bear The_Josh_Bear is offline
The_Josh_Bear is starting off with a positive reputation.
FORDF250HDXLT--
Sweet mod and update! Thanks for posting.
Question-- Why put the intake over the brake booster? Why not just cut the tabs off the air cleaner, then rotate it towards the passenger side, and cut a easier, bigger hole over there? I was looking out on my truck earlier today and it seems a better spot, you wouldn't have to crush the tube at all.
Thoughts?
Thanks,
Joshua
  #51
Old 04-02-2011, 09:18 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Do you have a/c? If not, it would be a little easier depending on how you do it.
  #52
Old 04-02-2011, 09:19 PM
well i eventually want to do that side as well.but a little fabing is required to cut a hole on that side of the air cleaner housing.im sure it wouldn't take that long to do,and should get around to that.
  #53
Old 04-02-2011, 09:20 PM
I think he is saying to cut the nubs off by the intake flange so you could rotate it towards the pass. side.
  #54
Old 04-02-2011, 10:00 PM
BlueOvalBud's Avatar
BlueOvalBud BlueOvalBud is offline
BlueOvalBud is starting off with a positive reputation.
Quote:
That's what I got out of it also.
I think that would also work. The lower air filter assembly has those tabs, cut those off, spin the housing to the passenger side and then run the hose to the cowl that way. Put the filter back in, put the lid on, bolt it down and go, go, go!
  #55
Old 04-03-2011, 02:40 PM
Snaponprofile and blueovalbud you guys are right on.
Sorry I wasn't real clear.
I was just thinking that if you want one intake that would be the side to do it on, since you could have a full 4" hole cut.
And I do have AC(doesn't work), but even still the lines could easily be pushed a bit out of the way. There seems to be plenty of room.
I wonder what the best way to seal the tube to the firewall is? It's not a flat surface on the passenger side like over the booster.
Thanks!
-Joshua
  #56
Old 11-10-2011, 04:58 PM
oops i meant to edit post 1,not reply.
  #57
Old 11-10-2011, 05:00 PM
lmao.well 3rd times the charm.
oh i see what the deal is,the thread is too old to edit now.only a quote button.my bad.
  #58
Old 08-08-2014, 11:18 PM
jakegaisser's Avatar
jakegaisser jakegaisser is offline
jakegaisser is starting off with a positive reputation.
What's a good air filter? several brands available at oreilly and napa, ranging from $12 to $65
FORDF250HDXLT what are you using?
  #59
Old 08-08-2014, 11:22 PM
it's a K&N filter sold with the banks turbo kit.ah i see.this was back when i was n/a (i ran a round K&N back then too.)
well im still using the same setup just hooked to the banks intake.which by the way doesn't really seal.i need to fab up a whole new setup sometime when i find time.
  #60
Old 08-08-2014, 11:25 PM
oreilly has K&N for $65, but mine is not turbo, its part number E1460
I'm guessing I would be best off getting the K&N then?
I have a list of things that are going to be replaced and its all adding up quickly, but I can tell a lot of maintenance has gone unchecked on this truck.
Air cleaner question tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-09-2015 06:14 PM
I got beef with this "zoodad" mod countryboy73703 1999 to 2016 Super Duty 10 01-03-2012 05:10 AM
Short "ram" air vs "cold" air intake 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 11-20-2011 10:22 PM
Getting maximum fuel mileage MPG's out of your IDI BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 04-15-2011 10:50 PM
fuel economy mods,tips & examples: congrats to David85 for hitting 25MPG! FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-18-2010 10:52 AM
Tags
2004, 69, 73, cowl, custom, diesel, f250, idi, induction, insulation, intake, navistar, project, rigs, soundproofing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
