Merc vs. Ford
Merc vs. Ford
Hey does anyone know if Mercury trucks ever made thier own interoir parts or did they just always use Fords. I have located a 68 Merc Ranger body that is in better shape than the Ford that I am looking at. But it has all Ford name tags inside. They are all Merc except for the Ranger emblem on the box. Interesting note on the Merc it has a overdrive off of the 4spd trainny thats being run by a 390. its there but it apparently doesn't work. Ohwell
Thanks in advance
Travis
Thanks in advance
Travis
Merc vs. Ford
I'm not sure about the 1968 Mercury. But you can find your answer maybe on the mercury web site. www.mercurypickup.com
I even think the guy the runs the site has a 1968 Mercury truck.
I have one but its a earlier model. I have a 1952 Mercury 1-ton
4 door pickup. GOOD LUCK !!!!!!!
Merc vs. Ford
The mercs had unique interior parts like horn buttons and radio blockoff plates up to the early fifties only as far as I've seen. After that up to 68, they used exterior nameplates only. The only gauranteed way to tell an original 67-8 would be the build sheet (rarely found) but sometimes found under or behind the seat. Other than that, the dso code on the bottom right corner of the door tag is a clue. If it has an A1-7 code in that position, that indicates it went to a Canadian Lincoln/Mercury dealer, which, before late spring of 68 would indicate a Mercury truck. I have found, however, a few mercs that have a B (Ford) dealer code, too. If anyone out there has an original merc with the build sheet intact, please contact me.
mike
mike
r_reed
28
01-11-2013 07:56 PM
cdwyer
07-14-2001 04:30 PM
