Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 02-15-2003, 02:58 PM
tmk411 tmk411 is offline
Garage is empty, add now
tmk411 is starting off with a positive reputation.
Merc vs. Ford
Hey does anyone know if Mercury trucks ever made thier own interoir parts or did they just always use Fords. I have located a 68 Merc Ranger body that is in better shape than the Ford that I am looking at. But it has all Ford name tags inside. They are all Merc except for the Ranger emblem on the box. Interesting note on the Merc it has a overdrive off of the 4spd trainny thats being run by a 390. its there but it apparently doesn't work. Ohwell
Thanks in advance
Travis
  #2 (permalink)
Old 02-16-2003, 07:01 PM
TryMe's Avatar
TryMe TryMe is offline
TryMe is starting off with a positive reputation.
Merc vs. Ford
I'm not sure about the 1968 Mercury. But you can find your answer maybe on the mercury web site. www.mercurypickup.com
I even think the guy the runs the site has a 1968 Mercury truck.
I have one but its a earlier model. I have a 1952 Mercury 1-ton
4 door pickup. GOOD LUCK !!!!!!!
  #3 (permalink)
Old 02-23-2003, 03:47 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
Merc vs. Ford
The mercs had unique interior parts like horn buttons and radio blockoff plates up to the early fifties only as far as I've seen. After that up to 68, they used exterior nameplates only. The only gauranteed way to tell an original 67-8 would be the build sheet (rarely found) but sometimes found under or behind the seat. Other than that, the dso code on the bottom right corner of the door tag is a clue. If it has an A1-7 code in that position, that indicates it went to a Canadian Lincoln/Mercury dealer, which, before late spring of 68 would indicate a Mercury truck. I have found, however, a few mercs that have a B (Ford) dealer code, too. If anyone out there has an original merc with the build sheet intact, please contact me.
mike
  #4 (permalink)
Old 03-01-2003, 06:18 AM
mercuryblues mercuryblues is offline
mercuryblues is starting off with a positive reputation.
Merc vs. Ford
Mercury trucks were only made in Canada 1946-1968 . If it has a A1-7 its a Ford
__________________
1959 M100 383/700r4
1970 T-Bird 429/360hp
1955 Ford Ranch Wagon
  #5 (permalink)
Old 03-03-2003, 06:30 PM
mk's Avatar
mk mk is offline
Merc vs. Ford
You might wanna take another look at the shop manual info. 'B' was Ford dealer, 'A' was Lincoln/Merc dealer.
mike
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
