Old 11-18-2014, 12:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Towing and Hauling Guides
Print Wikipost
Bed Tie Down Anchors
Old 09-16-2010, 03:17 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Thats cool that you got them all in. What do you mean by metal sleeve in the front 4 holes?
Old 09-16-2010, 06:22 AM
presidentsdad's Avatar
presidentsdad
presidentsdad is offline
The back two holes literally just have the hole in the top of the bed rail and open space underneath. The front four holes have a metal sleeve inserted in the hole that is flush with the hole, making it impossible to install the pocket anchors without pushing the sleeve out (i.e. toward the bed on one side and toward the outside of the truck on the other side) to allow the entry angle and subsequent rotation needed to install the anchors. Basically, I had to make the inside part of the hole (not the stake pocket hole itself) about a 1/4" wider.
Old 09-16-2010, 11:00 PM
TexasGuy001
I'm not sure what those peices are that your talking about. They may have been there from another accessory that was installed at some time.
You didn't have to trim them at all for the front and middle pockets? I did, because I wanted to be able to get them back out if I ever needed to replace them.
Old 09-16-2010, 11:27 PM
presidentsdad
I'd have to look at another truck (which I'm doing tomorrow at pull-a-part) but the sleeve or insert is there for added strength for the stake pocket. The guy at Bull Ring said they would fit, but I'd have to bend the interior sleeve a little (he was right). IT could be that my truck has the "camper" package (according to the build sheet) and that could be the reason for the sleeves.
cbservicesmn
2017+ Super Duty
02-01-2017 02:07 PM
TexasGuy001
05-30-2013 01:23 AM
06silvercrew
1999 to 2016 Super Duty
12-20-2010 05:09 AM
Bossman7121
02-02-2004 10:33 AM
ben towe
Oil & Lubrication
03-21-2001 03:32 PM
Quick Reply: Bed Tie Down Anchors
